1978 - 1996 Big Bronco
bouncing speedometer needle and t case squeak
Old Dec 8, 2011 | 11:11 AM
fordbroncodave's Avatar
fordbroncodave
1989 ford bronco xlt 5.0 5 speed (was an aod but i switched it) 1356 trasfercase with lever.
recently my speedometer cable got wrapped around my front driveshaft when it let loose and both needle bearing cups shattered. i replaced both u joints and inspected the straightness of the shaft and all checks out. it squeaks like none other. i can only pinpoint it to be the front somewhere. with the truck not running or moving if you grab the front bumper and move up or down with it you can hear the squeak in the front somewhere.
it is definitely A driveshaft or axle shaft as it only make the noise while the hubs are locked in and or in regular 4X4 or 4 low
also, new speedometer cable and sensor and gear and my speedometer needle is bouncing while i drive.
help please
Old Dec 8, 2011 | 01:25 PM
Edgethis's Avatar
Edgethis
There are alot of bushing that could be squeaking under the front.
As for the t-case squeak and needle bounce. Sounds like you prolly broke a tooth on the gear inside the transfer case that spins the cable. Shouldn't be too hard of a fix. Also inspect the speedo cable itself, it may need replacing.
Old Dec 8, 2011 | 06:23 PM
fordbroncodave
the speedometer cable is brand new as well as the sensor and the yellow gear inside the transfercase. the cable is dorman brand and the other 2 pieces i got from ford.
Old Dec 8, 2011 | 06:48 PM
AzPete's Avatar
AzPete
Sounds like there is a tight bend in the cable routing somewhere.
Old Dec 8, 2011 | 07:15 PM
fordbroncodave
from the original routing path all i changed was put it on top of the frame rail and zip tie it to 2 holes. still retains the same path, just out of the way of the fuel lines.
not exactly cut to fit as it comes pre assembled otherwise i could have tried to make it a straight shot.
does the sensor/ yellow gear need any lube?
Old Dec 8, 2011 | 08:07 PM
AzPete's Avatar
AzPete
Should be self lubing from the tranny.
Put the new cable in the exact position of the old and see what it does.
Also...it is possible you got a bad one out of the box.
thejermsr
Apr 5, 2015 01:57 PM
80skeys
Jun 12, 2010 03:05 PM
69WestCoastFord
Jun 30, 2009 07:40 PM
Jet Lizard
Sep 10, 2004 03:46 PM
fordranger68
13
Feb 29, 2004 10:56 PM
