Sponsored by: Real Truck
Front hub replacement
Old Nov 20, 2011 | 07:34 AM
PMB44's Avatar
PMB44
Hi Guys
I need to replace my front hub assemblies on my 1999 F250 5.4 4x4. There are a lot of options for replacement but here is my problem- truck was manufactured in 01/99 making it a "1ST EDITION". The hub flanges are different thicknesses (10 mm vs 13mm) and will not work with newer rotor/brake parts. Is there a conversion kit that can ne purchased? Is there a easy way to tell if it has already been modified? I need to replace the hubs for winter because I am worried about losing 4 wheel drive. Also should I replace my tie rod ends and ball joints now too? Any help is appreciated thank you.
Old Nov 20, 2011 | 08:00 AM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT
So are your wheel bearings (hubs) bad, or are you having problems with your lockouts?
Old Nov 25, 2011 | 07:16 AM
PMB44's Avatar
PMB44
I believe the bearings are bad.- the ride is quite noisy with an intermittent clicking upon low speed braking. Brakes are fine. Thanks
Old Nov 25, 2011 | 09:16 AM
Steve_250's Avatar
Steve_250
Check the front rods for twist play and ball joints for up & down play.
I did mine last year, rides much better.
Do you want to put in manual locking hubs?
If so, there are lots of threads on here and also articles.
Folks have been going with Warn hubs.
Not expensive.
Old Nov 25, 2011 | 10:19 AM
IROCKWITHDIRT
Yeah, I'd get it up in the air....... pull the wheels, and give it a shakedown. Could also be the needle bearings the axle stub shaft rides on have failed.
Old Nov 26, 2011 | 06:29 AM
PMB44's Avatar
PMB44
Wheel bearings
Thanks guys! I am going to check her out tomorrow. I have been researching the Warn hubs and they seem to get bad reviews -any other brands you suggest?
Old Nov 26, 2011 | 08:14 AM
IROCKWITHDIRT
When I bought my truck the locking hubs were completely non functional ( locked all the time regardless ). Following this : Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page took about 15-20 min a side to rebuild / lubricate. They work fine now.
Getting the ESOF (if equipped) functional is a whole other animal, but more likely than not servicing will get them functioning manually.
Old Nov 26, 2011 | 10:59 AM
rikosintie's Avatar
rikosintie
Summit Racing has the Mile Marker hubs on sale for $90.00 right now. They seem to have a good reputation.
Michael
bashby
Jul 18, 2012 10:14 AM
Chequamegon
Oct 5, 2011 01:04 PM
gvandyke
Aug 1, 2008 07:24 AM
cjspack
Jan 5, 2007 11:57 AM
84 BroncoBoy
1978 - 1996 Big Bronco
Jan 30, 2004 11:23 PM
