Sponsored by: Real Truck
clutch/ starting issue
Old Nov 25, 2011 | 04:33 AM
capt_don's Avatar
capt_don
my clutch was just changed in a 99 f250, now it won't start. lights, glo plugs work, just wont crank, what gives?
Old Nov 25, 2011 | 07:42 AM
OverReved's Avatar
OverReved
Who changed the clutch? I'll assume it was you, or else the shop would have to deal with this problem. My first guess would be that one of the wires to the solenoid is either broken, pinched or pulled from it's connector. Get out the jumper cables and a couple of test leads and outboard the circuit to the starter to see if it will turn over the engine. Then get back to us with your results.
Old Nov 26, 2011 | 01:27 AM
capt_don's Avatar
capt_don
clutch2
clutch and hyd system were changed in shop, i drove it away, it started twice more then nothing. suspect system needs bled? or anyway whatever sensor that won't allow to start unless clutch depressed. also brake light on dash no longer working, are they related? same harness? jumped solenoid to start
Old Nov 26, 2011 | 07:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
Clutch safety switch?
Old Nov 26, 2011 | 11:09 AM
carltonwebb's Avatar
carltonwebb
Did u check to see if the bolts were tight at the starter and all the wires connected there including grounds?
grimmkrowe
Aug 25, 2017 08:35 AM
90F250351
Aug 30, 2007 09:12 AM
OhioCats250
Sep 30, 2004 07:12 AM
chadbuddy34
Mar 23, 2004 03:22 PM
