Changed glowplugs running rough?
Old Nov 19, 2011 | 07:40 PM
Nonturbo's Avatar
Nonturbo
I changed all 8 glow plugs in my 97 7.3 today. It fired right up but runns like it might not be firing on a cylinder. It dosent seem like it is running bad enough to be missing to be but cant think of what else it could be doing. Could I have a lose wire under the valve cover or is it someting else?
Thanks, Austin
Old Nov 19, 2011 | 07:48 PM
bryanlindborg600's Avatar
bryanlindborg600
did you mess with any of the under valve cover harnesses? pretty hard to not know if you took off the injector connector.. just a thought... people do forget things..
Old Nov 19, 2011 | 09:07 PM
Nonturbo's Avatar
Nonturbo
I only purposely took of the glow plug wire. Didnt know if it was easy to unplug an injector accidently or not. I checked the connectors on the outside of the valve covers.
Old Nov 19, 2011 | 09:13 PM
F350-6's Avatar
F350-6
Do you have a CEL? I've knocked an injector plug loose before while re-installing a valve cover. Makes for a slight miss and throws a CEL.
mybigredford
Nov 5, 2014 07:03 PM
yardman116
Jun 28, 2010 12:23 PM
donny3369
Nov 13, 2008 05:05 PM
clawson3
May 25, 2007 11:13 PM
outdoor79
Dec 11, 2005 10:59 PM
