7.3 skipping
Old Jun 27, 2010 | 05:46 PM
yardman116's Avatar
yardman116
7.3 skipping
I have a 1996 f-450 power stroke that is only running on the four cylinders on the drivers side.
Unplugging two connector (injector conn) on pass side valve cover does not affect engine.
HELP................
Old Jun 28, 2010 | 07:11 AM
Lazy K's Avatar
Lazy K
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums Here is a link to the page for your engine. I`m sure the guys there will be able to help you if you repost your problem there.
Old Jun 28, 2010 | 12:23 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Check the UVCH(under valve cover harness). the valve cover gaskets have connectors on them on the inside and outside for the glow plugs and injectors. They like to melt down over time. I would start by pulling the valve covers and checking those plugs.
huskvrna
Aftermarket Products
Dec 2, 2002 07:25 PM
Petrol
Nov 2, 2002 11:31 AM
vettehauler
Paint & Bodywork
Oct 30, 2002 07:33 PM
welder man
Paint & Bodywork
Sep 29, 2002 08:01 PM
Brian460
Aug 13, 2002 12:08 PM
