vacuum improvement
Old Nov 19, 2011 | 09:28 PM
86f2504x2's Avatar
86f2504x2
Also I changed 1 of the e-brake cables but did not hook it up to the pedal cable yet. Could the spring at the end of the new cable in the drum be stopping me from bleeding that side fully because its putting pressure on the shoes away from the drum?
Old Nov 19, 2011 | 09:32 PM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by 86f2504x2
Should the truck be on the bleed them.
Say what? I understood well until that. Please explain.
You did the bleeding in the right order. However, I've had many instances where it took several rounds to get all the air out.
Ahhh, I've re-re-re-read. You mean "should the truck be on to bleed them?". It isn't necessary. All the vacuum does is to multiply your leg muscles. But, you do need someone to bleed while you pump or vice versa. Or, use a bleeder like a Mityvac, but I have one and don't like using it.
Old Nov 19, 2011 | 09:36 PM
Gary Lewis's Avatar
Gary Lewis
Don't think the e-brake will cause a problem like that as my cables are slack unless the e-brake is on and I was able to bleed it nicely.
Old Nov 19, 2011 | 09:40 PM
86f2504x2's Avatar
86f2504x2
Well wtf. Don't know what else it could be. Why pressure when its off but not when its on
Old Nov 19, 2011 | 09:47 PM
ctubutis's Avatar
ctubutis
My suspicion is a problem with the brake booster.
Disconnect & plug the vacuum line to the booster, start it up and see how things behave.
Old Nov 19, 2011 | 09:48 PM
Gary Lewis's Avatar
Gary Lewis
Are you saying you have good pedal when the engine is off, but not when it is running? That the pedal is up and very firm when off but goes to the floor when running?
If so, maybe we need to back up a step. Did you say that "the light is on"? IIRC, the light is telling you that one side of the master cylinder has more pressure than the other, which should mean that either one side of you master cylinder isn't working properly or that you still have a lot of air in that side and it is compressing and not bringing the pressure up.
So, tell me about the light.
Old Nov 19, 2011 | 09:55 PM
86f2504x2's Avatar
86f2504x2
Its just a brake light but I'll bleed them again tomorrow. Thanks for the help. I'll post again after that.
Old Nov 19, 2011 | 09:59 PM
Gary Lewis's Avatar
Gary Lewis
Oh, brake light. My bad. Ok, tomorrow.
Old Nov 20, 2011 | 07:42 AM
Franklin2's Avatar
Franklin2
Did you adjust the shoes? If you just stuck them on there, that could be your low pedal. You need to manually adjust them out while turning the tire till you can't turn it anymore, and then back them off till it turns with a little bit of rubbing. This is only for the rear, the front discs adjust themselves.
jeffreyclay
Jul 3, 2019 07:00 PM
bsraborn
39
Jun 21, 2017 01:30 PM
yankeerebel
Nov 10, 2009 06:56 PM
geodiggr
Aug 13, 2009 04:06 PM
northerndave
Feb 22, 2008 11:35 PM
