Idle mixture questions
Old Nov 4, 2009 | 12:29 PM
yankeerebel's Avatar
yankeerebel
I am trying to adjust my mixture at low idle. When I have the screw backed out only about 1/2 turn the engine begins to pick up speed and run smoothly. The problem is there is no change between 1 turn or until the screw falls out. It has been suggested that the needle valve venturi may be blocked from when I cleaned and rebuilt the carb. If I remove the screw entirely and put my finger over the hole shouldn't there be a slight vacuum? Can I squirt solvent in there and blow it out with mild compressed air? Your thoughts?
Old Nov 4, 2009 | 12:41 PM
Jermafenser's Avatar
Jermafenser
What do you mean, "low idle"?
If the idle mixtures don't change whenever you adjust till it closes or falls off the carburetor, it's a pretty good indicator you have a bad vacuum leak.
If it does change behavior from closed to 1 turn, then it sounds OK. It's easy and accurate to adjust the idle mixtures if you use a vacuum gauge.
Old Nov 4, 2009 | 02:42 PM
yankeerebel
"Low Idle" ...the idle mixture adjuster on the passenger side.
I do get an appreciable change from closed to 1 turn but I thought it should begin to stumble after becoming too rich.
I'm getting a vac guage later this week. Where can I find more explicit instructions on using the vac guage for mixture? I.E. where to hook the guage and what the readings should look like?
Old Nov 4, 2009 | 03:41 PM
Jermafenser
Curb idle?
Using a vacuum gauge is really simple. There are few animated illustrations on using a vacuum gauge on the internet. Hook the gauge to the manifold vacuum source, that would be the tree at the back of the engine.
If the engine is healthy, the needle should be steady. Adjust the idle mixture until it reads 17-21 Hg.
Old Nov 9, 2009 | 07:22 PM
yankeerebel
Thanks for the help Jermafenser. I got the vacuum guage and within 5 minutes had both mixtures dialed in. Initial vacuum was <15"Hg and a few turns and I was at 21"Hg with rock steady idle. Truck starts from cold and drives 100% better! This also solved my stalling at stop signs issue. Turns out it was not the carb float or a vacuum leak as I had suspected...just really poor mixture!
Old Nov 9, 2009 | 09:10 PM
fmc400's Avatar
fmc400
MSEE
My vacuum gauge is easily the best tool I've bought.
Old Nov 10, 2009 | 12:39 AM
Jermafenser
Glad you got it dialed in. Tuning usually solve an underlying problem most of the times!
Old Nov 10, 2009 | 07:30 AM
Tees77f150's Avatar
Tees77f150
How to Use and Interpret a Vacuum Gauge
I know you already got it tuned, but for those who search, and need a little more help, this a good overview.
Old Nov 10, 2009 | 06:56 PM
Tees77f150's Avatar
Tees77f150
Plus one there brother!!!
Just a side bar, today I hooked up my vacuum guage, and adjusted my idle, choke, air.fuel mix, and timing, and it really runs like a top now.
Since my rebuild, I had a little trouble with cold starts. After it was warmed up it started fine, but now it runs like a new truck!!!
Oh yeah, the vacuum is 17 hg now.
lee
Aug 3, 2015 11:30 AM
JayzDaddy
Nov 28, 2014 07:43 PM
1984Ford300six
19
Aug 29, 2014 12:12 PM
D. DeBoer
Jul 12, 2014 07:38 PM
bryan_johnson
Jul 27, 2002 12:12 AM
