Another Turbo Question
Old Nov 19, 2011 | 02:50 PM
Sheryle's Avatar
Sheryle
I bought a replacement turbo solenoid pigtail and don't know which wire is which or if it makes any difference. The 6E7Z-12A690-DA is used on the turbo solenoid and/or the IPR valve. Perhaps that is the reason the wire colors don't match. I have a blue wire and a black with blue stripe wire coming from the harness and purple and yellow wires on the replacement. Could someone tell me which wire goes into the solenoid plug on the right side facing the plug? I'm talking about the female plug attached to the solenoid. Is it blue or black? I think the old male plug was heat stressed because it pretty much crumbled when I unplugged it. Thanks
Old Nov 19, 2011 | 05:07 PM
cheezit's Avatar
cheezit
if you plug the new connector in the blue wire should be the one closist to the fire wall.
hope that helps ya.
Old Nov 19, 2011 | 05:23 PM
Sheryle's Avatar
Sheryle
Thank you cheezit. That is exactly what I need.
alpha/omega
Jun 6, 2011 11:02 AM
Amboy Tom
Oct 25, 2008 03:37 AM
Amboy Tom
Oct 22, 2008 02:06 PM
Ed in Maine
Nov 26, 2007 01:33 PM
Rich in CO
Sep 2, 2007 07:39 AM
