Location of EBPV plug on 2000 PSD
Old Oct 23, 2008 | 10:47 AM
Amboy Tom's Avatar
Amboy Tom
I am trying to wire up an exhaust brake on my F250 Ford (auto tran) and am not sure I have located the 2 plug wire that controls the exhaust back pressure valve on my truck. I believe it is located at the base of the turbo pedestal facing forward. The color of one wire is grey w/red stripe the other is red w/yellow stripe.
Are these the correct colors for my 2000?
Thanks for your help.
Tom
Old Oct 23, 2008 | 10:51 AM
stroke-of-luck00's Avatar
stroke-of-luck00
that should be it. it's the only plug on the front of the turbo pedestal right under the turbo. I actually unplugged mine last night.
Old Oct 23, 2008 | 11:00 AM
Action4478's Avatar
Action4478
Pic ....
Old Oct 23, 2008 | 11:23 AM
superduty4x4's Avatar
superduty4x4
Its the only one in that neighborhood- center of the motor on the front of the turbo with 2 wires. Me thinks you got it.
Old Oct 23, 2008 | 11:59 AM
03_PSD's Avatar
03_PSD
this might be a dumb question but how do you get that unpluggend, how do you get that wire piece off??
Old Oct 23, 2008 | 12:06 PM
superduty4x4
You just flip it up, its a lock tab.
Old Oct 23, 2008 | 12:24 PM
03_PSD's Avatar
03_PSD
I knew it was a dumb question....lol
Old Oct 23, 2008 | 01:02 PM
superduty4x4
We'll forgive you, but only this once
Old Oct 24, 2008 | 03:22 PM
Amboy Tom's Avatar
Amboy Tom
Thanks for your input. Dumb me - what I thought was the pedestal was actually the base of the Y on the pressure side of the turbo not the actual base of the turbo. Thanks to the photo that Action 4478 provided I see where the actual turbo pedestal is.
You mention that you pulled the plug off on your truck but it appears to me that in order to splice into those plug wires I would have to take the inner cooler hoses off as well as those that feed the engine and then actually remove the Aluminum Y plenum from the turbo outlet. Am I seeing that correctly? If this is the case I am not sure this engine brake is worth it.
And again many many thanks for all your help.
Tom
Old Oct 24, 2008 | 05:29 PM
dpwilson's Avatar
dpwilson
If you don't want wire a switch in for that and a torque converter lockup I would suggest calling Jody at dptuner. You can get an awesome chip for performance and a program with the same function as exhaust brake. All you would have to do (once chip is installed) is hit a button.
Old Oct 25, 2008 | 03:37 AM
ron's power stroke's Avatar
ron's power stroke
i have the SP diesel exhaust brake and TC lock that will fit your truck..its a plug and play mod and lets you set the tc lock and unlock speed of your choice with out the playing of a switch..for more info on it click on exhaust brake and it will take you right to it..im gutting my EBPV and Jody will take care of the tc for me..so i no longer need it..
http://www.spdiesel.com/
F250_Super_4X4
Dec 19, 2016 10:21 AM
79Supercab
Feb 22, 2015 10:16 PM
thaugen
Large Truck
Jul 31, 2012 09:23 AM
kawirider00
Apr 7, 2011 12:23 PM
lewyk
Aug 16, 2009 07:55 AM
