sensor response from throttle
Old Nov 19, 2011 | 10:56 AM
cadetspider06's Avatar
cadetspider06
Question sensor response from throttle
Which sensor respopnds to throttle imput in order to fire the injectors?
Old Nov 19, 2011 | 01:08 PM
njneer1's Avatar
njneer1
TPS......throttle position sensor
Old Nov 19, 2011 | 03:31 PM
cadetspider06
I already replaced that one any other ideas?
Old Nov 19, 2011 | 05:41 PM
big-ugly's Avatar
big-ugly
Clean your throttle body, check fuel pressure, possibly clean/replace injectors?
Old Nov 19, 2011 | 09:57 PM
rikard's Avatar
rikard
Depending on year and engine, it could be the MAP or MAF sensor. Pull the codes.
regards
rikard
Old Nov 19, 2011 | 11:56 PM
cadetspider06
Regarding the MAP sensor, the truck acts the same weather or not its plugged in but when its not it turns on the check engine light. It goes away when I plug it back in. Is that what you mean by pull the codes? The check engine light?
Old Nov 20, 2011 | 07:26 AM
rikard's Avatar
rikard
No, go to fordfuelinjection.com for info on pulling the codes with a paper clip or jumper. They also have a description of what the codes mean and what each sensor does.
regards
rikard
Old Nov 20, 2011 | 07:47 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Yeah, the nice thing about computer controlled engines is they'll tell you exactly what's wrong if/when a part goes south.
Old Nov 20, 2011 | 01:13 PM
Heather09's Avatar
Heather09
Question Help
I have an 06 F250 with a 5.4L engine. I brought the truck into the shop and ran it on our new scan tool pulling codes P0121(tps circut A fault. Both banks 1 and 2 are lean and there s a misfire upon seeing the 1st 1,000 rpm seems like an intermitten problem there. Also showing codes P2104( throttle acuator-forced idle) and P2112( throttle acuator stuck clodsed) I believe much of my problem may be my tps needing cleaned or replaced, however the truck is also going into failsafe mode where it will die and start right back up, only doing this on occassion. I am going to clean the throttle body, MAF and TPS sensors and c if this helps fix the problem. I dont want to take it to a dealer because after reading some additional post ,most of them cant fix the problem either.
Old Nov 20, 2011 | 03:46 PM
cadetspider06
I can't get the fordfuelinjection site to load. If I could get pic of how to set up the code check it would be very helpful.
BigBlue92
Mar 7, 2025 08:39 AM
makuloco2000
Feb 27, 2014 10:26 PM
rusted&busted
Sep 8, 2008 01:17 PM
LiveFast
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 3, 2004 07:46 PM
wildjon300ci
May 23, 2002 02:33 PM
