Injector Replacement?
Old Nov 18, 2011 | 04:29 PM
johnarahill's Avatar
johnarahill
Hey fellas, I have the vc's off my 7.3, have 165,000 miles on it. I'm doin the fifty cent while I'm in there, and I ohmed out the pins on the harness for each injector at around 3 ohms. I'm wondering if I should replace the injectors while I'm in there. I also noticed the rear injector is a different color than the rest. What's up with that? Would you change them out, and where should I go for stock injectors?
Old Nov 18, 2011 | 04:39 PM
BigAlsPSD's Avatar
BigAlsPSD
If you have the availability of it being down you could send them to be flow tested and cleaned or possibly rebuilt. I would not just change them personally unless you just wanted to do it, they're a little pricey to just replace because. The rear most on the driver's side could be a LL/AE(Long Lead) injector as it was a cure for "cackle" complaints, and offers a slightly larger pilot shot than the others.
Here's where I go for injectors, Clay also offers New stock replacements.
Riffraff Diesel Performance Parts: Diesel fuel injectors | Ford Powerstroke fuel injectors | 7.3L Fuel Injector - Full Force Diesel / Casserly
Riffraff Diesel: New Alliant Stock Injectors
Old Nov 18, 2011 | 07:17 PM
F350-6's Avatar
F350-6
The ohm readings are fine. Is there any reason you think you need to replace them, or is it just from mileage?
Old Nov 18, 2011 | 10:38 PM
Bonanza35's Avatar
Bonanza35
If its running fine leave it. They can run a long long time. If you want more power like stage 1's ect., go for it. They are not spark plugs.
Chet
Old Nov 18, 2011 | 11:38 PM
johnarahill
I'm not looking for any additional power, just hate taking my truck down and figured I might give it a shot since I've got access to them. I guess if it ain't broke a won't fix it on this one...
truck7575
13
Feb 21, 2018 09:39 PM
johndeerefarmer
Jul 24, 2016 07:13 AM
Hawk180
Jul 10, 2012 07:14 AM
hndamxmn
May 9, 2009 03:24 PM
wolfe1104
21
Mar 5, 2008 09:21 PM
