Idle Validation Switch
Old Oct 11, 2009 | 02:56 PM
MustangMatt96GT's Avatar
MustangMatt96GT
I need one.. Mine is broken, where the switch still works, but the tip that touches the pedal stop no longer touches. This causes the truck to never think its back to the NO throttle postition... The truck no longer clicks when you press the pedal... I don't know how long it has been like this, but what type of issues would this cause when driving?
Also where can I just get the switch? I dont want the whole pedal assembly.
Old Oct 11, 2009 | 03:36 PM
MustangMatt96GT
Well after discovering this, I decided to take my truck out for a drive... Runs and drives like normal.
Still would like to get a new switch, since that is how my ICP mod is wired up, so the truck idles normal, just when the throttle is pressed, it uses the resistor...
Anybody have a spare just laying around?
Old Oct 12, 2009 | 08:42 PM
Oversize's Avatar
Oversize
Denver Used Ford Parts where I sent you before still has a red 94.5 there with some pieces left including the pedals as of last weekend depending on the case mention me again and Id bet you could get the whole ctuch pedal assembly including the switch for about $25.
Old Oct 12, 2009 | 08:50 PM
strokin'_tatsch's Avatar
strokin'_tatsch
ok here is what you need to do.. see that tab on the pedal that the IVS should touch???? bent it in a little until the IVS clicks AS SOON as you touch the pedal, but make sure it clicks back everytime. if its not touching that is your problem. doubt the IVS is bad
Old Oct 12, 2009 | 10:34 PM
MustangMatt96GT
From another genisus other than me( im stupid)
Drill a little hole in the tab, then tap it, then install a little screw (without head, I dont know how do you call it) and add a nut in the back of the tab to fix it against the tab, and in that way you can adjust it easily as much as you desire: in or out. EASY FIX.
I owe that dude a Hug... It sucks having to reach down and click the switch to get the truck to rev up and not just idle...
But I did Call Denver Ford Parts... they wan 75 bucks for the IVS, TPS, and the accelerator pedal... If this screw thing does not work, i will be picking that up on Wednesday.
Old Oct 12, 2009 | 10:43 PM
Hussler's Avatar
Hussler
Buy it now !!!! that is really, really cheap for the entire assembly.
Old Oct 13, 2009 | 12:17 AM
Oversize's Avatar
Oversize
I like that repair idea makes good sense. If you do have to go to denver ford. Ask for larry and reference me he should give you a little better deal since I do some much business with them. Tell him your getting it for me if it helps hopefully he'll give it to you for my price that way.
Old Oct 13, 2009 | 12:40 AM
MustangMatt96GT
Will do if needed! Thanks, I think my screw thing is going to work though...
Old Oct 13, 2009 | 02:04 AM
strokin'_tatsch
why don't you simply bend the tab?!?! its easy as hell to do. we pull the tabs out to get better response from the pedal, but it will work the same for you if you just push the tab in. you might have to use a small pair of pliars but still.. i wouldn't go drilling and tapping nothin. too big of a pain for something that probably takes 10 seconds tops to fix.
Old Oct 13, 2009 | 09:23 AM
MustangMatt96GT
The tab will not bend far enough without getting the torch out... I tried this...
Old Oct 13, 2009 | 10:53 AM
strokin'_tatsch
it will, trust me. i have bent one so far it that the pedal just wouldn't go back to its original position.. it would stick up off the floor a ways.. LoL. you do gotta give it a little force. maybe a small hammer?? for me pliars, grab the end, hold the pedal out and prying it always works though.
Fat Slob
18
Jul 27, 2016 06:20 PM
91ford7.3
15
Jul 10, 2016 04:22 PM
Gembone
15
Oct 31, 2015 07:18 PM
punchy1
May 28, 2012 07:26 PM
hardwaterfreak
Dec 22, 2011 07:56 PM
