Thinking about hydroboost
Old Dec 19, 2011 | 11:25 AM
  #31
eatont9999's Avatar
eatont9999
I was going to see about getting the F450 MC but if it won't work with my rear brakes, I will just use the new MC I bought for the F250.
Old Dec 19, 2011 | 11:30 AM
  #32
oreocreaming's Avatar
oreocreaming
You can always get a mid80's MC. Iirc the cast iron ones are a direct fit as well
Old Dec 19, 2011 | 11:38 AM
  #33
eatont9999's Avatar
eatont9999
Is that better than widening the holes on the one I have?
Old Dec 19, 2011 | 03:00 PM
  #34
Onus's Avatar
Onus
The effort increase on the pedal has to do with the larger master. With the increase in the bore diameter the master creates more psi in the lines by pushing more volume but it takes more mechanical advantage to do so.
Good brake article
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
Old Jan 15, 2012 | 09:57 AM
  #35
eatont9999's Avatar
eatont9999
I wasn't planning on doing the hydroboost for a while given the weather but this weekend has been in the mid 60s, so I decided to do some more work on the truck. I could have done the whole hydroboost conversion this weekend but the dealer didn't have the PS pump reservoir in stock. They wanted $40 for it and it would be here Monday.
Instead, I changed out the front rubber brake lines that I couldn't get off last time. An 11mm flare wrench fit much better than the SAE one I was using.
I have a few more questions for y'all, though. The fluid that came out of the hydroboost was awfully dark, would that mean a problem? It also had a very nasty odor to it. Which line should the filter and cooler be installed on? I know it needs to be on a return line but now there will be two of them.
Thanks.
Old Jan 15, 2012 | 07:02 PM
  #36
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Have a read for the cooler and filter info.......
https://www.ford-trucks.com/forums/1...-brakes-2.html
Old Jan 15, 2012 | 07:32 PM
  #37
FORDF250HDXLT's Avatar
FORDF250HDXLT
ah that's too bad.the power steering/hydro system should be flushed every year really.
the hydroboost unit should be treated like the ip for the engine.with very close tolerances that can cause trouble with very little contaminants.that's why i installed a filter along with my cooler in the return line.
what do you mean you'll have two return lines?
Old Jan 15, 2012 | 07:35 PM
  #38
eatont9999's Avatar
eatont9999
One coming from the hydroboost and one coming from the steering gear. That's why there are two return nipples on the F450 PS reservoir. I was just wondering which line is better to have the cooler and filter on. I would assume the one with more fluid flow.
Old Jan 15, 2012 | 07:46 PM
  #39
FORDF250HDXLT
oh,the one that comes up from the steering box you just hook in directly.
you want you cooler/filter in the return line after the hydro.
you don't want to have to frig with extending the ps box line,making a loop and hooking it in back under there for anything.
Old Jan 15, 2012 | 11:50 PM
  #40
eatont9999's Avatar
eatont9999
OK, I see. I like your little cooler that you have installed. I want to install mine before the radiator and if it is at all possible, I would like a small spin-off type filter. I may be going overboard but I don't want to have over heating issues and I would prefer to spend $40 now on a filter and head than $20 for a filter every year for the rest of my life. Yeah, I kinda like my truck...a lot...
Old Jan 16, 2012 | 12:18 AM
  #41
finitetime's Avatar
finitetime
OK this is probably a dump question but what is hydroboost? I have read several threads on it and everyone talks about where to get parts and how to install it but what is it? How is it different from a regular brake system and why do you put it on your truck.
Old Jan 16, 2012 | 01:07 AM
  #42
Marianna2003's Avatar
Marianna2003
No such thing aS A "DUMB" question. It's a hydraulic operated booster vs. a standard vacuum operated booster.
Old Jan 16, 2012 | 11:29 AM
  #43
tecgod13's Avatar
tecgod13
I have no idea if you can find a small spin off filter, but my guess is it would be more than the other ones.
I picked up a plastic one at Autozone for $9.99 a couple weeks ago when I put my saginaw pump in. The pump seems nice, is quieter, doesn't leak. Unfortunately, it looks like the steering box is leaking again
Old Jan 16, 2012 | 04:00 PM
  #44
FORDF250HDXLT
here ya go:
Brake & Front End: The Complete Undercar Service Magazine
that can be done.the superduty trucks use coolers mounted up front for max cooling.just need a little more hose is all.
you can use a spin on type filter system too if you prefer.
http://www.fleetfilter.com/filter/wi...ses/24764.html
http://www.fleetfilter.com/mm5/merch...Category_Code=
Old Feb 25, 2012 | 07:01 PM
  #45
eatont9999's Avatar
eatont9999
OK fellas, I can now join the hydroboost club!
I belted out the whole job in about 5 hours and that was taking my time and enjoying a few cervesas and a trip to the parts store to get a new brake fluid reservoir because I couldn't get the old one off.
I have the stock pedal installed right now. I find it stiff but the truck stops very quickly and I don't have to push very hard. If I did push hard, all of my crap in the truck would be in my lap! I already have to re-secure the spare E4OD in my bed because it came loose during testing.
I don't have the cooler or filter installed but I plan to add those to the system soon. After buying the $45 reservoir, I only had enough money to do with what I had. I still have to check for leaks but noting blew up during my testing, so I am confident I am good to go.
I may decide to swap the stock pedal for the HB pedal but I need to research more about the brake light connector and the cruise vac dump connector before I attempt that. Also, the pedal I have is from a 5 speed, so it is smaller and will definitely look odd and be harder to find.
