DPF Regeneration Questions
Old Nov 17, 2011 | 08:50 AM
kabur66's Avatar
kabur66
All . . . . I have low mileage problems with my truck that may be related to the generation of the diesel particulate filter. I have the following questions . . .
Are there two kinds of DPF regeneration systems, i.e. an active, and an inactive?
When do the regeneration systems work?
When do they start and when do they stop?
Is the inactive system on all of the time?
How do the engine exhaust temperatures respond to the regeneration processes? Typical values?
Thanks . . . . ken
Old Nov 17, 2011 | 09:17 AM
EpicCowlick's Avatar
EpicCowlick
The correct terminology is Active and Passive regeneration. The truck is capable of keeping the DPF clean all the time by itself if you drive in such a way that your exhaust temps are high and you are not flooring the go pedal. Think towing a good load but not racing up Eisenhower pass. This is the passive regeneration. The exhaust temps are high enough to burn out the accumulating soot.
Most of us don't drive like that and the truck has to take an active role in burning out the soot. When the computer detects a filling DPF, it "turns on" the Active regeneration process which is to inject diesel fuel into the exhaust stream which then burns at a very high temperature. This burns out the soot and cleans the exhaust filter.
Old Nov 17, 2011 | 09:28 AM
Whiteline's Avatar
Whiteline
Epic has a good description there, just to add a bit...
Typically an active regen will last 10 to 15 minutes on the highway. If I'm running 550-600 degrees rolling down the highway the EGT will go up to 700+ while regen is active, this is on sensor #1. Sensor #4, which is the sensor closest to the tailpipe, the DashDaq monitors will typically climb to 1100-1200 degrees while regen is active.
Old Nov 17, 2011 | 10:47 AM
Hdslider's Avatar
Hdslider
In addition to that if you constantly do short drives and it can't get cleaned out it will eventually give you a drive to clean exhaust message.then you will need to take out and give it just a good long drive.If you get to that point it will take a good while to get dpf clean.
Old Nov 17, 2011 | 09:15 PM
kabur66's Avatar
kabur66
Thanks Epic, Whiteline, and Hdslider for the information. This is a very interesting system.
ken
bwisecup
6.7L Power Stroke Diesel
Mar 20, 2018 12:33 PM
JRD761
Jun 3, 2015 06:34 PM
2011 Ska Tatanka
39
Jun 30, 2014 10:59 PM
motivationteam
45
Aug 18, 2012 06:59 AM
wharrell
42
Jul 18, 2012 06:20 PM
