Little or No DEF Usage. Concern?
Old Jul 9, 2011 | 10:38 PM
wharrell's Avatar
wharrell
Have put 1600 miles on my F350 since I last check the DEF. I could only drizzle in 16/100 of a gallon so appears I am using little or no DEF. That much could have even evaporated in the summer heat.
Should I be concerned?
If I understand correctly, the DEF should continuously be sprayed into the exhaust to reduce NOX and to keep the EPA happy. I do have regenerations as frequently as every 70 miles when some in town driving is involved and about every 175 miles on mostly highway driving. If my knowledge is correct, the DEF is totally independent of regeneration to burn off the soot in the Diesel Particulate Filter.
It appears I may have a failed DEF pump or sensor of sorts. Although I am not getting any codes on the command center display or thankfully, no Check Engine Light, I presume the dealer should be able to hook the truck up to diagnostics and determine of the DEF pump or sensor associated with it is bad.
Any else seeing this?
Note: I do get the brief 2 second message notifying of the truck going into Regen, but like everyone else, mine does not stay on the way it did with my 2008.
Old Jul 9, 2011 | 11:22 PM
EpicCowlick's Avatar
EpicCowlick
The frequent regens and lack of DEF usage are indicators of your driving style. Sounds like you use your truck in mostly short trips and no trailer. That would cause a relatively quick build up of soot in the DPF requiring frequent active regens. Since the exhaust is not really heating up, the truck is not able to utilize passive regens. Also, DEF is only injected into the exhaust when exhaust temps are very high. It is only in this environment that NOx is created so therefore the NOx sensor is not detecting any. No NOx, no DEF being used. Sounds like the truck is doing what it should.
Old Jul 10, 2011 | 05:48 AM
AMEC Electric LLC's Avatar
AMEC Electric LLC
I've had four regens in 5600 miles. I have not towed with it yet.
Old Jul 10, 2011 | 08:14 AM
Tom's Avatar
Tom
I agree with Epic on this one.
Remember that your truck has a sensor for NOx in the exhaust system. If you had un-treated NOx passing through the system the sensor would allow the computer to detect this. If the computer tried to increase the DEF dosage and saw no reduction of NOx, as would happen if you had a DEF pump failure, you would see a check engine light.
Remember that the EPA required these trucks to be nearly foolproof with how they treat the exhaust gasses. There are many redundant checks to ensure that the system is working properly, if you have no CEL on there's nothing to worry about.
Old Jul 10, 2011 | 08:39 AM
tolliewolly's Avatar
tolliewolly
I have had a few filter cleans but my truck has never went into regen
Old Jul 10, 2011 | 08:46 AM
rickatic's Avatar
rickatic
exhaust filter message equals regeneration...Epic and Crazy001 are correct about the DEF. Hook up a big trailer to that beast and run it down the highway. You will see DEF usage...have fun with that new truck
Old Jul 10, 2011 | 12:25 PM
Tangi Cowboy's Avatar
Tangi Cowboy
If your not using DEF, I would say that before long you will see a warning that you have contaminated exhaust fluid & you will restricted to 55 per hour in 200 miles, this has been happening to me for a while & the warning always went away before the 200 miles occured. One of the four dealers I went to pulled up a bulletin that indicated loose wires on some sensor. Now the light stayed on and sure enough the struck is restricted to 55 miles per hour, but the computer tells me the reservoir is full. I have talked to serveral service peeps & they have no clue to the problem. So,Tuesday I'm taking mine to leave at the shop in McComb, they will be able to find the problem hopefully, I'm hoping it will be a simple fix.
Old Jul 10, 2011 | 04:16 PM
wharrell's Avatar
wharrell
Edit:
Pulling out the technical documents on the DEF system, it get sprayed into the exhaust stream after the Diesel Particulate Filter.
Old Aug 13, 2011 | 11:00 AM
wharrell's Avatar
wharrell
5900 Miles: Still no DEF usage since I had my DEF tank topped off the week after delivery.
I do not regularly tow, but do use my truck most weekend here in the NC Mountains.
Either I have a failed sensor, failed DEF pump or crimped DEF line that has been reported on some trucks. Having the dealer sweep for codes next time I am in.
Old Aug 13, 2011 | 11:04 AM
Tom's Avatar
Tom
Exactly how do you know that you've used none? Have you tried to add some?
Old Aug 13, 2011 | 11:28 AM
Hdslider's Avatar
Hdslider
they dont have a quage like a fuel guage. level okay, below half or a warning at 800 miles. if you dont tow, chances are your using very little. if in doubt add some and see.about $12 at o reiley for 2.5 gallon jug. even walmart has it.
Old Aug 13, 2011 | 08:31 PM
mach8274's Avatar
mach8274
I have just over 6000 miles on mine and have used almost 5 gallons of DEF. Just before our 2000 mile trip in July, I had the oil changed and DEF top off. The truck had 3k on it at that point. It took about 2.5 gallons then. Now at 6000 miles, I checked the message center again and DEF was under 1/2 full again. So, in 6k miles, I have used about 5 gallons of DEF. Over 3000 of those miles are towing.
Old Aug 13, 2011 | 09:25 PM
dixoncity's Avatar
dixoncity
Just had my oil changed at 5,300, no heavy towing, mostly highway usage, 4 gallons of DEF.
Old Aug 13, 2011 | 10:37 PM
KC8QVO's Avatar
KC8QVO
Around 4000 miles I added 2.5 gal after the 1/2 tank message (in the menu) and have close to 7000 miles now - no 1/2 tank message yet. I haven't pulled any trailers yet, but I have run a couple thousand miles with a loaded bed.
Old Aug 14, 2011 | 11:03 AM
Hdslider's Avatar
Hdslider
Most all i talk to. i have convinced to fill def as soon as they leave dealer,most are taking 2.5 to 3.0 gallons. another way for ford to save money.
