Hello guys I'm looking to buy a new Oem rpm sensor I used the Ford part number E5TZ-17B384-A on Google and I found the part but I'm not sure what I should be paying? I found one for 100 and one for 64 here E5TZ-17B384-A - Ford SENSOR ASY any help is appreciated. Oh and I also need a headlight switch where should I buy that?
I have herd you need the tach sending unit and that its a FORD ONLY part... im in the same boat man my needle wobbles like 3-400 rps. its on the list. and for the headlight switch. i would ebay that. im currently missing the small hollow screw that secures it to the dash... iys on the list..
I found that dealer pricing varied widely on this part. If you are in an area where you can, call around to various dealers. I saw prices from 72 to 96 bucks, then bought it at Madera Ford in CA for 52.
Ok well that site says its in cali so maybe 64 is the right price then.none of the sites I have seen even have a picture of the part.so is the tach sending unit different from the sensor asy I posted above
I did some searching, but I couldn't find a pic either but here is one mounted on a motor, it is the nut with two wires sticking out of it to the right of the oil fill tube.
I just bought one off Ebay for for 45$ the Uhaul guys had them for about 60$ when I was looking for one. just make sure it is the OEM part and new I will try to post a picture of mine later to day.
Dark horse what did you search for on eBay? I searched "tach" and "tach sensor" and found nothing under Ford f250 but I searched the part number and found one which is 102
Mostly I searched " Tach Sensor E5TZ17B384A " on Ebay also search Google and see shows When I found the one i ordered there were several to choose from ranging from 45.00 to 100. I only found 2 listed today .
Here is the site for Uhaul that lists it :
I don't know if that helps but it is the best info I have now (Remember new things get listed on Ebay all the time If your not in a big hurry I would wait a while and see if a better deal shows up.)
Reason: Edit link
