Tach/Engine RPM Sensor
Old Sep 27, 2004 | 10:24 PM
dieselhappy's Avatar
dieselhappy
Hello All;
I suspect my Tach/Engine RPM sensor is going. In the morning, when the truck is cold, the tachometer reads 200 rpm when fast idling. Then when the truck warms up, the tack indicates correctly.
I would like to test the sensor with my ohm meter. Does anyone know what the resistance should be? Or can anyone giv eme ideas.
Thanks all
Jeff
Old Sep 28, 2004 | 06:58 PM
csramsey640's Avatar
csramsey640
tach sensor is located at the top right beside your oil fill. They are not very expensive, id just try one. If it is an e40d, you will also feel harder shifting.
Old Sep 28, 2004 | 07:34 PM
dieselhappy
It is a standard tranny, i know where the sensor is i just want to test it. Ford wants 90 dollars for the damn part. Would like to test it first if anyone know the resistance tolerances.
Old Sep 28, 2004 | 09:16 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I think it actually puts out voltage. The more voltage the faster it is running.
I can not find the voltage range though right now.
Old Sep 28, 2004 | 10:51 PM
89ford73's Avatar
89ford73
keep a 1-1/8 wrench handy and test drive one from a dealership or somewhere and swap them out real quick.... thats wut i did
barkfarm
Mar 31, 2013 11:40 AM
Kentwa
Mar 17, 2012 11:11 AM
fhafer
Dec 26, 2010 04:02 PM
Sycostang67
28
Feb 14, 2010 02:04 PM
