Flywheel bolts?
Old Nov 17, 2011 | 07:46 AM
79OldBone's Avatar
79OldBone
Flywheel bolts?
So I am about to start my trans swap fri night and I just want to make sure I have everything.
Will the bolts from the flex plate work with the flywheel? Or are they too short? The new flywheel kit might have some? I havent looked yet. A buddy picked it up for me.
Do I have to grind that fin off the bell? Its a 91 ZF5 going in a 95.
I grabbed the skid from the 91 but are the trans skid plates the same? or cross member. whatever you'd like to call it.
Reverse lights... If I grabbed the little plug thats like 2ft long with the ZF does that plug right into the plug that would go with the auto? If not I guess I'll have to wire them up.
Old Nov 17, 2011 | 09:07 AM
Talyn's Avatar
Talyn
The flywheel should come with new bolts.
Be sure to check, if it's a LUK flywheel, the flywheel bolts might be to long.
If it didn't come with bolts, go get some new ones.
I thought you ordered a Valair?
be sure to use good loctite on the bolts also.
Old Nov 17, 2011 | 09:18 AM
79OldBone's Avatar
79OldBone
Well I was going with the Valair kit and a buddy just got a job at Bond so I got a Luk flywheel and clutch for almost nothing... But why would the bolts be to long? They have an issue with that?
mr lucky
Sep 5, 2022 10:35 AM
Rocky RaetzIDI
19
Mar 4, 2013 10:26 AM
Greg5OH
May 17, 2012 10:58 PM
loudfords
Aug 30, 2006 04:43 PM
hster
Sep 12, 2004 01:05 AM
