flywheel bolts
Old Sep 5, 2004 | 08:09 PM
hster's Avatar
hster
flywheel bolts
Hi,
1981 f 150 inline 6 4 speed manual on the floor. There are 6 bolts on the flywheel. The two on opposite sides of each other are being very difficult going in. I only have about 3-5 more threads to get in. Should I just keep using sheer force in putting them in? Will th epressure plat ebe this difficult?
thanks for any suggestions
Old Sep 5, 2004 | 08:30 PM
mark a.'s Avatar
mark a.
I would take it back apart and chase the threads out with a tap & put in new bolts if the threads are damaged on them. I would also use a round file in the press. plate holes, to remove any burrs.
Old Sep 10, 2004 | 08:08 AM
RTM's Avatar
RTM
It sounds like you may not have the flywheel positioned correctly and the bolts are not centered in the holes because of this?
Old Sep 12, 2004 | 12:57 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Don't force them in, you could find yourself re-threading the fly wheel... Do you have the clutch alignment tool?
Old Sep 12, 2004 | 01:05 AM
yota's Avatar
yota
never use force it will hurt you every time. not saying snug is bad but grunt force is never right. i also know on a lot of thies the bolt patterns are a one way thing i had one that with all but the last bolt in the last hole was off buy 1/4 inch unbolt move it around 1 hole and it went in easy? you tell me?
My 2 cents
cadunkle
Nov 19, 2016 06:59 PM
BuddyBarnes
13
Sep 10, 2016 11:51 AM
Nathan Cox
Aug 4, 2015 01:54 PM
ford_boy_1996
Nov 13, 2007 08:15 PM
