Sponsored by: Real Truck
Power Window inop
Old Nov 17, 2011 | 12:06 AM
ArcticF250's Avatar
ArcticF250
Power Window inop
The left rear window in my 06 f250 crew cab will role down but not up. I pulled the motor today and tested it on the bench and it worked fine. The switch checks out good also. It will not go up or down with the drivers door switch. Is there a relay somewhere that may be bad?
Old Nov 17, 2011 | 09:56 AM
counciller's Avatar
counciller
Have you checked for power at the plug for the motor? Also i think some motors will run fine when not under load but will stop when loaded
poppop50
Jan 7, 2021 09:14 PM
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
Campsta
Jan 22, 2018 09:17 AM
gad4wd
2004 - 2008 F150
Feb 18, 2008 10:33 AM
Dutch123
1978 - 1996 Big Bronco
Nov 22, 2004 09:32 PM
