Sponsored by: Real Truck
Cold - Click - No Start
Old Nov 16, 2011 | 08:46 PM
Grumpy Moose's Avatar
Grumpy Moose
Unhappy Cold - Click - No Start
Forgive me if this has been discussed before.
Has anyone experienced the symptoms of a dead battery when cold? Went to start this morning, not really that cold, "only" about 0F. Turned the key and click - engine doesn't turn over just like a dead battery. But I knew that the battery is an almost new Die Hard, and I even put a float on it a few weeks ago before winter set in and confirmed it was just fine and fully charged. So I kept trying and eventually the engine finally cranked and started up like nothing was wrong. Same thing happened leaving the office today as well, was about 5F.
Anyone have any insights?
Old Nov 16, 2011 | 09:56 PM
Dave G.'s Avatar
Dave G.
Check the red battery cable connection at the starter. They are notorious for rotting off a few strands at a time. That connection is right under the the engine and exposed to water, salt, brush. It can be repaired with a #4 welding cable lug and some solder ( if that's the problem).
Dave
Old Nov 16, 2011 | 10:34 PM
jh818's Avatar
jh818
Maybe the relay?
Old Nov 17, 2011 | 01:09 AM
Grumpy Moose
Thanks. Will check these out. That in fact seemed to be my first observation too - everything in the truck was getting adequate power, except the starter.
Old Nov 17, 2011 | 01:23 AM
BigAlsPSD's Avatar
BigAlsPSD
Is it an automatic? Your shifter doesn't happen to be sloppy does it? It's another possibility, if it acts up again try shifting to neutral.
If a manual trans maybe the CPP(Clutch Pedal Position) sensor.
Old Nov 18, 2011 | 08:55 PM
Dangy's Avatar
Dangy
Man I saw your post and signed up here!
Exact freaking thing happened to me last night. Drove it in the morning and wont start at night. Definitely something related to cold. Read somewhere about a cold intake valve which gets stuck? I actually could feel it having problems on cold mornings from the last two weeks. Any ideas would be great. Now only if I knew where these things are located on the ranger :lol:
Old Mar 26, 2020 | 06:30 AM
HVFDFIREFIGHTER1618's Avatar
HVFDFIREFIGHTER1618
Good place to start is the battery connections. Clean up real good maybe even use a little grease. Next is the ground connection to truck. Then check to make sure cables are good and if proper size. 6 volts like their juice!
Another thing with a float charger. Make sure it actually works. I bought three before I finally got one that works like it should.
Old Mar 27, 2020 | 08:49 PM
Connecticut Calvin's Avatar
Connecticut Calvin
Go here https://www.ford-trucks.com/forums/forum41/ and the click on Start New Thread.
edit: wrong thread. That’s what I get for using my iPhone.
majorn00b
1983 - 2012 Ranger & B-Series
Dec 16, 2012 08:07 PM
TerryW
Oct 13, 2008 11:00 PM
briansrapier
Jun 15, 2007 07:35 AM
quick35th
Oct 11, 2006 07:29 AM
trevwalker
1997 - 2003 F150
Jan 7, 2004 08:46 AM
