OD light flashing
Old Nov 16, 2011 | 06:33 PM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
OD light flashing
So going to dinner tonight and noticed the OD light flashing. So I drove about a mile shut the truck off restarted it and the light was off and the OD button worked so I drove that was about 5 miles and it never came back on shifted fine and ran good. Ill pull the codes tomorrow but in the mean time what do you guys think happened.
Old Nov 16, 2011 | 06:35 PM
BigAlsPSD's Avatar
BigAlsPSD
Hard to tell without a code? But could be transmission range switch or VSS. Were you fully engaged in a gear on the column shifter?
Old Nov 16, 2011 | 06:36 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
hard to say till you check the codes.... Were you towing recently? How many miles on your truck?
Old Nov 16, 2011 | 06:55 PM
7.3bo-ti-etr
225000 on the truck. No towing and I was in drive.
Old Nov 16, 2011 | 08:22 PM
woodnthings's Avatar
woodnthings
Mine started doing that when it was slipping. The computer can see it is slipping more than you can and if it sees a difference it can throw a code. You need to pull codes to really find out though........otherwise we are all guessing.
Old Nov 16, 2011 | 09:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
NOBODY knows what is wrong without the codes.
Old Nov 17, 2011 | 11:25 AM
Rick2001's Avatar
Rick2001
It happened to mine too. All I had to do was replace the OD button. Its an easy fix. But yes its best to get the codes!
Old Nov 17, 2011 | 12:07 PM
7.3bo-ti-etr
Codes are
B1318
B1373
P0500
P0475
P0541
Old Nov 17, 2011 | 12:31 PM
PaysonPSD's Avatar
PaysonPSD
The important one:
P0500 VSS Vehicle speed sensor malfunction Sensor, circuit, PCM, PSOM, TR failure, low trans. fluid
The others:
P0475 EPR Exhaust pressure control valve malfunction Open/grounded ckt., solenoid open/shorted, failed PCM EBPV delete?
P0541 MIAH Manifold intake air heater... Open/short circuit MAIH delete?
The B codes are body codes and I don't have a list for those.
Old Nov 17, 2011 | 10:42 PM
7.3bo-ti-etr
Driving home today noticed the speedo not working tossed the truck up in neutral restarted the truck and worked fine. Got the new sensor so we'll see what happens tomorrow.
Old Nov 18, 2011 | 04:01 AM
mueckster's Avatar
mueckster
B1318 Battery Voltage Low
B1373 Illuminated Entry Relay Short to Battery
djf36
Apr 27, 2012 07:00 AM
landcruzr
Dec 24, 2009 08:59 PM
dale716
Feb 2, 2008 04:19 PM
highboy390fe
1997 - 2003 F150
Sep 1, 2006 09:43 AM
