flashing overdrive light
Old Aug 13, 2003 | 05:35 PM
dale716's Avatar
dale716
I just got back from Towing through the Colo mountains. During one incline, my overdrive light came on and started flashing. When I turned the ignition off and back on it quit flashing. It did the same thing the next day. The rest of the time it did not flash and the overdrive would kick in and out when I pushed the button.
When I got home I dumped the codes and found that the computer hadn't stored any codes.
Any suggestions on what could have been the problem and why didn't the computer store a code if there was a problem severe enough to cause the light to flash?
Old Feb 2, 2008 | 03:43 PM
WH90's Avatar
WH90
that light indicates there is something wrong with the Transmission take it to Ford before it gets damaged, i didnt do that and i had to replace mine
Old Feb 2, 2008 | 04:19 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
WOW, you are going way back. Look at the dates before you Post to a thread. Do you think he fixed it by now. lol
