help if you can Please :)
#122
#123
#124
Right on Bro been waiting for this day to come for awhile
Are you shure Its oil coming out the tailpipe [Soot and coolant can look like oil]
only thing I can think of is a Bad turbo seal usually the cause of Oil out the tailpipe
Did you replace the turbo??
#125
oh its oil its a half a quart on my shop floor. I replaced it with a used one. I took it apart cause it looked bad and I cleaned it all out and put it back together. This turbo was supose to get me by until I could buy a powermax cause my old one broke in half. But maybe I need to get a powermax sooner than later.
#126
#127
yeah I took the unison ring out and vains out and cleaned them all up and took the piston out and I worked the crank back and forth for like 2 hours cause it was all gummed up inside. So I had to keep spraying penetrating oil in it and solvents to get it to move a little more free. I got it off ebay
#128
I bet the turbo is bad and is the problem
I hear stories of stuff like this off E bay I would be to scared to get it off Ebay
that sucks Sorrey Man
read this maybe you have but I thought that I would post anyway
https://www.ford-trucks.com/forums/1...ml#post9449262
#130
I have found a rebuild service I am going to use. Electro diesel out of texas will rebuild it for $375 Its a full rebuild completely disassembled with a complete rebuild kit bead blasted, bead blasted, rebalanced, veins are resurfaced, It sounds like I will basically have a new turbo and comes with a warranty. I just cant afford a new powermax and finish the hunting season they say they have a 1-2 day turn around
#131
I just want to say thank you for everyone's help I am going to post one more on here tomorrow with some pictures of the broken pieces out of the oil rail. I have to say This no start problem is finally fixed thanks to all of you. Have a merry Christmas and I will start a new thread for the turbo and update you with the rebuild service and how they do.
Thank you again you guys are great
Duke
Duke
Restlesswildman
08-15-2017 10:54 PM
jason poeppel
03-23-2017 01:23 PM
jdonthewater
07-28-2010 07:08 PM
