5w 40?
Old Nov 30, 2011 | 04:13 PM
Dyllan78's Avatar
Dyllan78
5w 40?
Ive been reading that with a higher mileage truck its good to eventually switch to 5w 40, is this a good idea, what about synthetic. Dont want to drag this out to a big discussion. Just getting ready for the winter. thanks, I have 170,000
Old Nov 30, 2011 | 05:30 PM
69cj's Avatar
69cj
5w40 is a synthetic oil. Mileage doesn't matter. I've been using it since the engine had 10,000 miles. Great in all weather conditions and temps.
Old Nov 30, 2011 | 06:13 PM
Mich6.0's Avatar
Mich6.0
Like wise here, it actually quites it down too and truck seems to run better
Old Nov 30, 2011 | 06:30 PM
69cj's Avatar
69cj
Just make sure the oil you use is an API rated CJ oil and your good to go. I do stick with major brands. Rotella T-6 is priced pretty good at Walmart.
Old Nov 30, 2011 | 07:33 PM
JonArmy's Avatar
JonArmy
Ya I switched to 5w-40 this last change and I can tell the truck is a little quitter and starts up better since right now the tempature has started to drop to freezing in the morning and it starts good.
Old Nov 30, 2011 | 08:17 PM
sandmanf250's Avatar
sandmanf250
5x40 syn
put it in and forget about it.works great.
Old Nov 30, 2011 | 09:53 PM
Dyllan78's Avatar
Dyllan78
thanks guys
Old Nov 30, 2011 | 11:55 PM
Gental Ben 2's Avatar
Gental Ben 2
Just switched to the 5/40 & it does seem easier to start & less 'clatery'; where I live it's pricey @$120 but if it keeps it in one piece a bit longer then worth every penny!
Old Dec 2, 2011 | 11:57 PM
ramsay's Avatar
ramsay
Mileage doesn't matter. Mines got 265000 and i'm using Rotella T6 synthetic. Changed oil at 8000 miles last oil change and the lab test can back normal with a recommendation to stretch interval out to 10,000 miles. Can't complain about that....
Old Dec 3, 2011 | 10:00 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
That's impressive. At $120/change, anything people can do to SAFELY extend the drain interval is like money in the bank.
Did Blackstone do the test?
What is your driving like - short or long trips, towing or no?
Ed
Ed@ficmrepair.com
Old Dec 4, 2011 | 08:00 AM
sammy77's Avatar
sammy77
It's funny, I thought I had a miss when I'd start my truck cold in the winter. Switched to 5w-40 a couple years back...problem was immediately gone.
Old Dec 4, 2011 | 09:10 AM
tonefordays's Avatar
tonefordays
When switching over to synthetic, is it ok that it mixes with the little bit of 15-40 that is still left in the engine? How will this affect the effectiveness of the synthetic?
Thanks.
Old Dec 4, 2011 | 09:31 AM
dhag911's Avatar
dhag911
I had my pickup into ford about why my milage went to hell in one tank and has stayed that way and it was smoking alot and of course it wouldnt smoke for them and they found nothing wrong. so i asked them about switching to 5-40 for the winter and they have never heard of any one running that so i looked in the owners manual and it doesnt say anything about using that oil either for any temp ranges. Would it void my warrenty if i went with 5-40 for the winter?
Old Dec 4, 2011 | 09:39 AM
69cj's Avatar
69cj
Thanks.
Will not hurt anything. Just for your info, there is approximately four qts. of oil left in the hpop system and no, you don't need to get it out.
Old Dec 4, 2011 | 09:47 AM
roadrunner01's Avatar
roadrunner01
After your truck was built/owners manual printed Ford allowed the use of 5w-40, and offers its own Motorcraft brand. What is in your owners manual is 10w-30, its what I use year around. Its much cheaper than a 5w-40 and its cold weather performance is about equal to it, I have used both and I don't think anyone could tell the difference.
A 10w-30 is much more shear-stable than a 5w-40 according to my UOA's, and like I said much cheaper, usually it can be had for $11-$13 a gallon vs. $19-$22 for the cheapest 5w-40.
