dp tuner radio interfearence
Old Nov 16, 2011 | 05:02 PM
red 1997 powerstroke's Avatar
i just installed dp tuner in my 1997 f 350 and i now get teribble radio reception i have tried every thing from wraping the tuner wire in tin foil and wire and grounding it to installing a ferrite /choke on the end of the cable and still no reception i have a pioneer stero in it any body have any ideas? would a antenna amplifier or filter help?
Old Nov 16, 2011 | 05:34 PM
Action4478's Avatar
Action4478
Have you contacted DP yet ?...
Old Nov 16, 2011 | 06:44 PM
towsrus's Avatar
towsrus
did you wire a ground in anywhere that shares a ground with the stereo or a 12v wire by chance? doing that can cause a interference problem. or also if your rca cables (if you have an amps/speakers) or speaker wires cross any paths with any wiring to your programmer wires
Old Nov 16, 2011 | 07:35 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I'm on my phone, so I can't run a search on this, but try researching Moates chip radio interference. The chips DP-Tuner uses comes from Moates. I have seen issues floating around here and there about Moates chips having radio interference issues, so maybe you'll come across something by searching that. I will search it when I get on my laptop at home too.
Old Nov 16, 2011 | 07:38 PM
ya i contacted them they said to check the radio ground and install a ferrriet on the end of the tuner cable i did both of these things and still no reception so im stumped
Old Nov 16, 2011 | 07:40 PM
DIYMechanic's Avatar
DIYMechanic
Any chance the antenna cable got unplugged somehow in the process of installing the tuner?
Old Nov 16, 2011 | 07:41 PM
i used the stock ford wiring foe the radio and the tuner justs plugs into to the pcm and i have no amps so i dont think i did but may b
Old Nov 16, 2011 | 07:43 PM
thanks for the info and i apreciate u looking 4 me if u have time ive been chasin this problem for almost a week now
Old Nov 16, 2011 | 07:51 PM
DIYMechanic
If you unplug the DP tuner does your radio work again?
Old Nov 16, 2011 | 09:29 PM
pjwoolw's Avatar
pjwoolw
Which chip and switcher do you have?
Old Nov 16, 2011 | 10:11 PM
ya if i unplug the dp or put the truck in acc the radio is fine
Old Nov 16, 2011 | 10:15 PM
i have a f5 dp tuner with a dash mount
Old Nov 16, 2011 | 10:52 PM
pjwoolw's Avatar
pjwoolw
Rotary or EX switch?
Old Nov 17, 2011 | 12:43 PM
strokin'_tatsch
Ok so you have RFI with the chip plugged in, but in ACC or chip unplugged there is no RFI...
I have to wonder if a ferrite bead on the chip cable would help, but I would start by contacting DP-Tuner and ask them how to eliminate the problem. They may just send you a different chip and switch to try out. If it still does it you may need to try checking grounds for your radio and maybe try a ferrite bead on the chip cable. If it still does it after all that, I'd just sell the DP-Tuner and switch to a tuner that uses TS style chips.
This issue has been associated with Moates chips/cables/switches for quite some time. Some people have no problems, some people do have problems. Whether it's a chip issue or vehicle issue, I'm not sure, but switching to a TS style chip will eliminate the problem.
EDIT: just saw you've already tried foil wrapping and a ferrite bead.... My bad.
Old Nov 17, 2011 | 04:23 PM
ok thanks for the info
