New member! first question...
Old Nov 16, 2011 | 04:56 PM
zola049's Avatar
zola049
and probably not the last
Howdy everyone. Bought my first ford a year ago.
2004 4x4 Ford excursion xlt. Been a truck guy all my life, dodge mainly. Just added twin girls to my litter so the truck had to go. Hoping to learn a thing or two from you guys.
First order of business are my front sway bar end links. Did a search and read a few threads on the subject. seems pretty straight forward. My question revolves more about lifting the vehicle. As ive never really done suspension work, what is the best way to lift the truck? I have a good floor jack and jack stands. I believe suspension parts are under load and need to be lifted a certain way to be worked on. is this the case w/ the sway links? Again, ive done motor swaps, swamp buggy/airboat builds, etc. but never had to do the suspension work so be easy on me!! thanks
Old Nov 16, 2011 | 05:53 PM
jasonodsky's Avatar
jasonodsky
Welcome and congrats on the Excursion and the expanding litter! The front sway bar will not be under any tension. So you are safe to just unbolt the old and install the new. You should not need to jack it since there's pretty good clearance.
When jacking otherwise, jack the axle under where the leaf spring is or near there. I've been told never to lift by the differential pumpkin, you could damage things. Make sure the jack stands and floor jack are rated for the weight of the Ex, which is 4 tons or 8000 pounds.
I use a 6 ton bottle jack and two 3 ton jack stands. You don't want this beast falling on you. 2 ton floor jacks just can't move this beast.
Old Nov 16, 2011 | 06:00 PM
zola049's Avatar
zola049
Thanks thanks.
So not under tension huh? That means that these things are pretty seized on!
I just about gave myself a hernia earlier today. That's why I thought it was under a load. So a can of on blaster is in order?
Old Nov 16, 2011 | 06:04 PM
zola049's Avatar
zola049
Sorry meant PB blaster.
Oh and thanks for the jack info. I have a 4 ton jack and all my stands are 3+ tons.
Old Nov 16, 2011 | 10:02 PM
jh818's Avatar
jh818
I use a 3.5 ton jack. Since I'm only lifting either end, and not all 4 wheels, it is enough. I use the pumpkin as the jack up point for the rear. I wouldn't suggest the pumpkin on the front since it is not centered as it is in the rear.
Welcome to FTE.
Old Nov 17, 2011 | 09:29 AM
Misky6.0's Avatar
Misky6.0
Zola,
Welcome to FTE & the Excursion brotherhood.
I replaced my front sway bar endlinks & bushings.
As long as the front end is level there is no tension on the sway bar.
IF you have only 1 wheel up on a ramp/curb then you have lots of tension.
I'm 2wd, so I don't have as much room underneath as the 4wd.
I bought a set of 12k lb ramps from autozone and they work great.
I just bought a 3.5 ton jack & 6 ton jack stands from Northern Tools
and they too work great. There was a review from a fellow Excursion
owner (and I need to add my comment as well).
Old Nov 17, 2011 | 12:30 PM
jasonodsky's Avatar
jasonodsky
Great point Misky6.0! I'm in rep hold so someone else will have to hit you up for that one.
Norma stitz
Nov 13, 2016 09:20 PM
P4IN COMM4NDO
16
Sep 26, 2016 12:02 PM
TheCurtster
Feb 20, 2014 11:26 AM
jspence105
Nov 11, 2012 11:04 AM
Black Lab
Garage & Workshop
Sep 27, 2005 07:58 PM
