The X has a clunk!?!
Old Apr 13, 2003 | 03:54 AM
Sycostang67's Avatar
Sycostang67
Unhappy The X has a clunk!?!
My In-laws just purchased a used 2000 Excursion Limited 4x4 with a V-10/AT. It has just over 82k on it. Right when you are about to come to a stop, it makes a clunk sound, and sometimes it will do it again when you take off. They brought it back to the dealer, (90 day drivetrain warranty) and they had it all day, and said they couldn't find anything wrong. They also took it to another shop, that suggested maybe the leaf spring bushings were bad. The dealer said the PO of the rig used it mainly for hauling a car around. Could that have anything to do with it? Also, I looked at the motor in this thing and where the heck are the spark plugs at? Does it have one of those new coil on plug sytems or something? Thanks for any help.
Old Apr 13, 2003 | 01:26 PM
XXXcursion's Avatar
XXXcursion
Post The X has a clunk!?!
Same problem with my X
makes a clunk when coming to a stop
brought it to the dealer and they told me my ball joints were
gone!
parts only cost $70 with shipping(no one had them had to order online)
The truck goes in this week so i will find out if that is what it is
The weird thing is that i can go off road and never hear the noise
Old Apr 13, 2003 | 04:01 PM
Sycostang67
Let me know if that works for you. I will inform my in-laws and tell them to get the balljoints checked just in case. Thanks for the info.
Old Apr 14, 2003 | 01:10 AM
Monsta's Avatar
Monsta
Sit. Stay.
Spark plugs are indeed under the coil on plug thingys. They are yellow on top.
As for the clunk, could be many things from caliper bolts to the slip-yoke.
If it were my truck I'd look into the slip yoke. Check out the Super FAQ located at the top of the Super Duty forum. There is a link in there for lubing the slip yoke.
Old Apr 14, 2003 | 12:10 PM
crewsr's Avatar
crewsr
Can you tell about where the klunk is heard. Mine had a klunk on the floor board driver's side. It needed body mount bushing work. Had it in several times till it was done right. Might be able to check with dealer to see what repair issues have been documented with that truck.
Old Apr 17, 2003 | 07:03 PM
XXXcursion's Avatar
XXXcursion
just got the truck back from the shop
the ball joints were completely gone
they were seized and had to be torched off!!!
Any way it fixed the problem i was having and now the only other noise i have is caused by the slip yoke
i will probably grease it this weekend
Old Apr 28, 2003 | 08:48 AM
Sycostang67
They got it fixed, the slip yoke was dry, pulled it off, lubed it up and now it drives like new. Thanks for the help.
scottjima
Jan 15, 2018 09:33 PM
cccullen
20
Feb 14, 2007 07:06 PM
kc2aqa
Aug 3, 2004 11:16 PM
ron4u
1997 - 2003 F150
Apr 24, 2004 02:11 AM
live4fire
1983 - 2012 Ranger & B-Series
Feb 12, 2004 11:06 PM
