1978 - 1996 Big Bronco
HELP: Headlight switch question...!
Old Nov 15, 2011 | 12:42 PM
calazo's Avatar
calazo
Question HELP: Headlight switch question...!
Hi all, I've been trying to remove the dash panel on my 94 rig to replace the rear/tailgate power window switch, but the headlight switch **** at the left keeps me from doing it... I tried pulling it and twisting it but it just doesn't come off, anybody have an idea of how to do it?, thanks...
Old Nov 15, 2011 | 03:38 PM
greystreak92's Avatar
greystreak92
Pull the **** all the way out. Look closely at the bottom of the "skirt" on the ****. there should be a narrow slot cut into it that runs parallel with the shaft. A very small flat screwdriver pressed up into this slot will release the spring-metal clip that holds the **** to the switch shaft. You will have to release the clip and pull the **** off at the same time.
Bird-Dog 250
Sep 13, 2015 12:11 PM
clemensfield
Jun 20, 2013 11:27 PM
Bill W
Dec 30, 2009 10:53 AM
10-4 Crash
Dec 27, 2006 02:53 PM
MintFord
Dec 23, 2006 07:57 PM
