Need Help.
i can not for the life of me get the lighter socket out of the dash of my 65, can someone tell me how they come out? it's got me stuck. While were at it how does the headlight switch **** come off of the shaft? Thanks for any input on this.
Otherwise, you'll be turning the whole tamale till Armageddon comes.
The inner portion of the lighter socket has a threaded stud on the end. The wire does not connect to this stud, because...
In between the stud and the wire is this little darlin' FEW14429A .. Lighter Fuse. It's shaped like a barrel.
This puppy threads onto the stud, it has a threaded stud on the other end for the wire...which just pushes on.
If your lighter doesn't work, this fuse is either missing or has blown. The originals had a hole in them, the later fuses do not.
If the fuse has the hole, stick a paper clip into it to reset the fuse.
thanks
FEW14429A .. Lighter Fuse / Obsolete
FREESE MOTORS in Monticello IA has THREE = 319-465-3541.
KLIMESH MOTOR SALES in Calmar IA has EIGHT = 563-562-3241.
GREEN SALES CO. in Cincinnati OH has TEN = 800-543-4959.
TISON MOTOR CO. in Estill SC has TEN = 803-625-2551.
MILLER OBSOLETE PARTS in Binghamton NY has ELEVEN = 800-546-7278.
SALEM MOTORS in Crookston MN has ELEVEN = 218-281-1338.
C1TZ15052A .. Lighter **** & Element Assy / Obsolete
GRIESEL MOTOR CO. in Okarche OK has ONE = 405-263-7242.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
ED BENNETT FORD PARTS in Lebanon PA has ONE = 717-272-8762.
No other Ford Dealer or obsolete parts vendor has any.
C1TZ15054A .. Lighter Element & Bezel Assy / Does not include the **** / Obsolete
This is the correct part for 1961/66. The 1967/72 replacement has a different bezel.
NOS PARTS SOURCE in Lenexa KS has ONE = 913-220-5746.
WESLEY OBSOLETE PARTS has THREE.
GREEN SALES CO has SIX.
No Ford Dealer, no other obsolete parts vendor has any.
C1TZ15055A .. Lighter Socket & Retainer Assy (outer shroud) / Obsolete
ED BENNETT FORD PARTS has ONE.
GREEN SALES CO. has FIVE.
NOTE: 1961/66: Ford offered a lighter installation kit that came with all of the above parts except the fuse: C1TZ15A044A = No one has any.
In 1967, Ford replaced this kit with another. It fits fine, but the **** and the element's bezel do not look the same.
C8TZ15A044A .. Lighter Installation Kit / C8TZ15A044A replaced C1TZ15A044A & C7TZ15A044B / Obsolete
FREESE MOTORS in Monticello IA has ONE.
CARPENTER NOS (OBSOLETE) PARTS in Concord NC has FOUR = 704-786-8139.
Fits: 1961/66 F100/1100 // 1967/72 F100/750 / 1961/74 Econoline.
