I have a 78 F150 2wd that I purchased about three months ago. It has a 460 from a 75 Lincoln in it, I pulled the carb to do a rebuild and found that the last person to tear it down has stripped some bolt holes and supposedly glued the breather stud in as it is probably stripped also.
So....with me not being able to tear it all apart I went to ebay searching for a replacement and found two that are similar is looks but they both have different part numbers. Could someone please decode these or tell me where I can find a web site that will help me I would greatly appreciate it.
1. D 7VE SAB 7C 12
2. D 7VE AAA A 7F 29
I would like to know the year and if possible the application they came off of.
these numbers may not be in the right order.....that is how I read them off of the tag.
Thanks very much
Leland
Reason: added info
