Two things
Old Nov 14, 2011 | 09:35 AM
ChristopherN's Avatar
ChristopherN
Two things
My rad drain plug is leaking. For replacement, is it as simple as pulling the old one off and putting the new on one with as little coolant spill as possible?
My brother replaced the brake fluid diverter last year and I just got around to re mounting it. My question is, there was a piece of hose attached to this barb looking thing. What's it for? I can't find anything in my Chiltons about it.
I haven't seen any fluids come out...
(having issues with picture displaying, let me know if you can't see it)
direct pic link.
http://pic.armedcats.net/c/ct/ctn91/...11113-1106.jpg
Old Nov 14, 2011 | 12:06 PM
White 97 xlt's Avatar
White 97 xlt
The link is NOT working either....
Old Nov 14, 2011 | 01:17 PM
Lazy K's Avatar
Lazy K
Not working for me either. Are you talking about the brake line T on top of the rear diff.? If so, the hose is the axle breather and the end should be fixed in a clip just below the bed.
Old Nov 14, 2011 | 01:25 PM
ChristopherN
Try this..
Old Nov 14, 2011 | 01:35 PM
Lazy K's Avatar
Lazy K
Yes, that is the rear axle vent. Should be a lenght of flexible pipe on it with anti dirt vent on the end of it. It should be long enough to reach a clip just below the bed. It is fixed high up to prevent water/dirt entering the axle lube through the vent. You should be able to make something up. Just make sure you don`t block the end of the pipe or you will get leaking axle seals.
Old Nov 14, 2011 | 01:37 PM
ChristopherN
If I get some tubing and say, a small fuel filter?
Old Nov 14, 2011 | 01:42 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Breather for the differential, IRC....
Old Nov 14, 2011 | 02:44 PM
Lazy K's Avatar
Lazy K
yes, that would work. use a hose clamp at both ends of the pipe.
Old Nov 14, 2011 | 04:04 PM
ChristopherN
Now for my other question.
My drain plug on the rad is leaking, it's not a normal looking plug to me so what I'm wondering is, is replacement just a simple take the old one out and a new one in??
Jake the Novice
Jun 26, 2018 08:13 AM
luv2offroad2
Mar 21, 2018 07:06 AM
82_F100_300Six
Mar 17, 2018 04:19 PM
ericconn
16
Dec 3, 2013 02:36 PM
timmygyu
1978 - 1996 Big Bronco
Sep 12, 2011 09:51 PM
