yep another oil thread
Old Nov 13, 2011 | 08:20 PM
jg96powerstroker's Avatar
jg96powerstroker
ok guys as most of you no, doing lots of work on my ps,t500, new rosewoods and other goods, i got the donaldson filter on its way, now on oil, iam thinking bout going with motercraft 5w40 the senthtic, i used to run mobil delvac and rotieala , ran 15w40 moter craft in my 93, it seamed to hold up good, so is it a good oil to use , and would you run a bypass or not ??? i no some of us are thanks guys
Old Nov 13, 2011 | 09:53 PM
oldbird1965's Avatar
oldbird1965
I recommend Shaeffer's 7000 and Shaeffer's all trans oil, opps, you have a stick. I run the FS2500 bypass and have had some good oil tests after 10k miles. Shaeffer's also gives free oil tests. Under some testing its been shown that the 7000 oil doesn't sheer down like most. Joey, I think, runs it to. You might want to call him on that.
Old Nov 13, 2011 | 10:10 PM
jg96powerstroker
FS2500 bypass oil filter | eBay what you think??? or buy new??? will need lines and filter
Old Nov 13, 2011 | 10:15 PM
jg96powerstroker
man 82 bucks for a case of 12 qts..... you been running it a while now glenn?your going 10k on oil change?? with bypass. what would it be with out bypass? thanks glenn
Old Nov 13, 2011 | 11:58 PM
oldbird1965
If you got that filter container off of Ebay then your almost there. Buy the two lines from FS2500 and a filter and your in business. I wonder what the reserve is? I pay 18 a gallon for the 7000. I would not go 10K without the bypass.
Old Nov 14, 2011 | 07:44 AM
tshrager's Avatar
tshrager
I've been runnin the rotella full synthetic for about a year now. It's a little pricey, 20-25 a gallon depending on where I get it, but I can drive to get it. Truck seems to really like it
Old Nov 14, 2011 | 06:54 PM
King7765's Avatar
King7765
Any of you guys get oil samples tested?
Old Nov 14, 2011 | 07:06 PM
oldbird1965
See post #2, LOL.
Old Nov 14, 2011 | 07:42 PM
King7765's Avatar
King7765
Ok, I reread my post... sounds stupid now.
Old Nov 14, 2011 | 08:22 PM
oldbird1965
King, I didn't mean to be a smart ***. I've been doing oil tests for many years now. They also **** me off, they keep telling me I have high lead and iron so I had a special test done and it showed everything normal. I guess a normal test is a chemical analysis where the special 'test' I did they actually look under a microscope at the oil. I'm starting to think they are a waste of time but Shaeffers does it for free.
Old Nov 14, 2011 | 08:34 PM
King7765's Avatar
King7765
It's all good. I also had an oil test done last week and it said it was high in Iron and Lead.
My test showed 33 for iron (average was 17)
My test showed 13 for lead (average was 4)
I was two quarts low at the test. No fresh oil in sample. 3300 miles at test.
Shawn MacAnanny
16
Feb 4, 2017 10:58 AM
jg96powerstroker
Oct 30, 2011 12:35 AM
e.alleg
Mar 7, 2009 06:30 PM
tjbeggs
18
Aug 8, 2005 08:33 PM
alfie623
Nov 16, 2003 03:01 PM
