Sponsored by: Real Truck
Oil Sampling and Testing
Old Nov 14, 2003 | 01:52 PM
alfie623's Avatar
alfie623
Anyone ever do engine oil sampling on their engines?
I work in construction and we do it to all our equipment, the cost is well worth it. For $15 per sample you can predict when you'll need to do and engine job or loose a final drive.
Since it costs $75 just for the oil and filter on my 6.0L I was thinking of sampling the oil to get an idea if 3000, 5000, or 7500 mile oil changes are necessary. I figure I'll change the oil at regular intervals at first to create a baseline but then start pushing the cycles and monitoring the oil to see if I can get 10,000 or 20,000 mile changes. I may need to swap the filter in between but the idea of cutting the cost of the change in half is appealing to me.
Let me know what you think?
Old Nov 14, 2003 | 08:13 PM
Jlower's Avatar
Jlower
I run a Gulf Coast By-pass Oil Filter and sample mine every 5K. I use Titan Labs for the analysis. So far, So good.
Old Nov 15, 2003 | 09:23 PM
wbarber_07458's Avatar
wbarber_07458
Another place that does oil analysis is Blackstone Laboratories. (http://www.blackstone-labs.com)
I haven't sent them any oil yet, but I have read good things about them.
Old Nov 15, 2003 | 09:57 PM
alfie623's Avatar
alfie623
JLOWER: how many miles do you have on the GCF? How many mile without draining the oil? I've heard of the GCF unit, but I'd like to hear from someone who uses it.
Old Nov 16, 2003 | 03:01 PM
Jlower's Avatar
Jlower
I now have 14k on Mobile Delvac 1 and the GCF, the oil analysis keeps coming back as "Like New" the filters are pulling out most of the soot and all of the particles.
According to GCF I shouldn't have to change it ever again. I'm not sure that I believe that just yet, but my oil is still transparent. We do have several USAF fleet vehicles with well over 90K-100K miles on the same oil at our base.
I have only had to change the GFC filter once so far. The recommendation is to change the GCF filter ($17.00/ try to buy them in bulk to save on shipping) every 10,000 and the factory every 25,000. The GCF filter will bring your total oil capacity up to 18-20Qts. You do wind up replacing about 3-4 Qts each time you change the GCF filter.
