EFI head on carbed engine
Old Nov 13, 2011 | 08:05 AM
86straightsix's Avatar
86straightsix
I was wondering if an EFI head will swap easily with my carbed head. I was at the junk yard to get some EFI ex manifolds and the could not resist the getting the head as well.
Old Nov 13, 2011 | 09:11 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
No worries, it will bolt right up and you'll gain ~.5 point of compression plus the chambers are supposed to be "fast burn" for better low end.
Old Nov 13, 2011 | 09:48 AM
86straightsix
Sweet. Is it better to port and polish exhaust only? Something about the turbulence and atomization always comes up when reading about doing the intake ports.
Old Nov 13, 2011 | 11:25 AM
Harte3's Avatar
Harte3
FORDSIX PERFORMANCE • Login
That thread is about porting. It's written for the SB6 but the principles are the same for the BB6.
Old Nov 13, 2011 | 11:50 AM
BaronVonAutomatc
The conventional wisdom on EFI heads is not to cut them for larger valves. They would be shrouded even worse and deshrouding ruins the fast burn. Porting will still help. Polishing usually refers to the combustion chamber; I'm pretty ambivalent on the benefits once you get past cleaning up ridges or casting flash that could turn into a hotspot. It's going to be covered in carbon soon enough anyway...
Old Nov 13, 2011 | 12:01 PM
86straightsix
That link only goes to log in screen. Can you post it again?
Old Nov 13, 2011 | 08:07 PM
Harte3's Avatar
Harte3
Well, it doesn't look like it is going to work unless you register for that site.
Old Nov 13, 2011 | 11:48 PM
kedwinh's Avatar
kedwinh
I'd suggest you register over there. Good site and some good people. Wouldn't say they are anymore knowledgeable than people here but sometime a different point of view.
Old Nov 14, 2011 | 08:59 AM
AbandonedBronco's Avatar
AbandonedBronco
Just be sure to have the head magnafluxed for cracks. EFI heads are known to crack easier than carb'd heads.
Old Nov 14, 2011 | 09:03 AM
f100jim's Avatar
f100jim
Just a couple of points.
The EFI heads are more prone to cracking than the carb heads. Make sure you have it magnafluxed before you use it. If you do any porting, be very conservative, they are thin wall castings.
If they have a different style rocker arm, make sure your valve train is properly set with the new head. I don't recall all of the flavors, but some rockers are adjustable, some are not. Just make sure you get the right amount of compression on the lifter piston.
Old Nov 14, 2011 | 10:38 PM
86straightsix
I will be sure to get that done. Any input on what the cost of that is?
Old Nov 15, 2011 | 10:57 AM
AbandonedBronco
I think a magnaflux is around $35 or so. Call around to a few shops and see what they charge.
Also have them check to see if it's flat. If it's warped, you'll need to have it planed, which I think is around $80.
Old Nov 26, 2011 | 02:20 AM
86straightsix
Luckily I live in the racing capital of the USA, Charlotte NC. Magnaflux cost me 5 bucks. The guy raced straight sixes for 40 years. Between the great people on this site and him, I can't go wrong.
So, porting and polishing... Do I need to use carbide bits? Or can somebody recommend, the best, kit of bits to get? (best= cheapest to get the job done properly).
Then match to mr. gasket #260.
Then use that size all the way back?
Old Nov 26, 2011 | 02:32 AM
fordman75's Avatar
fordman75
Don't forget to recurve the distributor. Due to the fast burn chambers you'll want to pull some of the total timing.
Old Nov 26, 2011 | 07:32 AM
BaronVonAutomatc
I've got to know. Now, I would tell anyone to get their head(s) and block checked for cracks before starting in on any machine work, but every time someone mentions "EFI head" folks start chiming in on how they're more prone to crack that carb heads.
Is this just conventional wisdom or has someone actually compiled data on head cracking in 300s? Where are they more prone to crack? And why? They're made by the same company in the same factory as the carbed heads before them, right? So what is it about EFI heads that makes them more likely to crack? The two extra bolt holes tapped for the exhaust manifolds? My carbed '86 has the EFI manifold bolt pattern for the intake/exhaust manifolds. Should I be worried about cracking?
I'm not saying EFI heads aren't more likely to be cracked, but where does this particular factoid come from?
