EFI head on carbed engine
Old Nov 26, 2011 | 11:44 AM
Tote-M-Pole's Avatar
Tote-M-Pole
I would also like to know about EFI heads being more prone to cracking. What is the story here?
Old Nov 26, 2011 | 01:31 PM
86straightsix's Avatar
86straightsix
Originally Posted by fordman75
Don't forget to recurve the distributor. Due to the fast burn chambers you'll want to pull some of the total timing.
How do I recurve the distributor? What do I need to buy?
Old Nov 26, 2011 | 02:16 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
You'll need:
a) a dial-back timing light - the stock timing marks don't let you read what's happening at RPM without one.
b) a set of distributor springs - Moroso sells a kit iirc.
c) patience - you'll be pulling the distributor, making changes, reinstalling, and testing a few times.
You're taking the distributor apart to swap the advance springs and change the rate at which the timing mechanically advances. It's not all that complicated, but does require some trial and error. Search around, there are some good write-ups on how to do it.
Option B is to find a shop that has a distributor testing machine and have them do it for you.
Old Nov 26, 2011 | 02:35 PM
86straightsix
Kit? Is there something I can get from auto parts store? Do I ask for a recurve kit?
As it stands right now my engine is stock except I have:
-offy c
-2 to 4 barrel adapter
-autolite 2100 w/ 1.08 venturi and #49 jets
-efi manifolds
-walker y pipe
-2.5 to 2.25 adapter on y pipe
-2.25 exhaust pipe
-don't know what muffler but its 2.25 size
-no emissions equiptment
-DS2 dizzy (from junk yard)
-DS2 coil (from junk yard)
-DS2 ignition module (from junk yard)
-19 in Hg of steadyish vacuum
installed.
Would my next priority be? The dizzy recurve?
Until I do recurve the dizzy, can I just stick allen wrench into vacuum advance on the dizzy, and back out the screw as much as possible?
Old Nov 26, 2011 | 03:26 PM
Harte3's Avatar
Harte3
"...can I just stick allen wrench into vacuum advance on the dizzy, and back out the screw as much as possible?"
What??? Any and/or all adjustments should be only in small steps with trial runs in between to determine the response.
Old Nov 26, 2011 | 03:37 PM
fordman75's Avatar
fordman75
Originally Posted by BaronVonAutomatc
I've got to know. Now, I would tell anyone to get their head(s) and block checked for cracks before starting in on any machine work, but every time someone mentions "EFI head" folks start chiming in on how they're more prone to crack that carb heads.
Is this just conventional wisdom or has someone actually compiled data on head cracking in 300s? Where are they more prone to crack? And why? They're made by the same company in the same factory as the carbed heads before them, right? So what is it about EFI heads that makes them more likely to crack? The two extra bolt holes tapped for the exhaust manifolds? My carbed '86 has the EFI manifold bolt pattern for the intake/exhaust manifolds. Should I be worried about cracking?
I'm not saying EFI heads aren't more likely to be cracked, but where does this particular factoid come from?
I've personally had 3 EFI heads that were cracked. I don't think I've ever had a 240 or carbed 300 head that was cracked. Warped yes, cracked no. I'm not saying they are more proned to cracking. But it sure seems like there are a lot more cracked EFI heads then carbed heads. I wouldn't worry about the head unless you develop an issue. But definitely have them magnafluxed before you sink a bunch of time or money into one.
Old Nov 26, 2011 | 03:42 PM
86straightsix
From what I have been reading, lighter spring is put in during recurve. So, using deductive logic, I wanted to know if reducing spring tension as much as possible on un-curved dizzy would net me any gains.
Judging from your response it is ludacris to think that. I don't really know what I'm doing. ( It was just a guess)
Is recurving the dizzy the next step to take? If so, what kit do I need?
Old Nov 26, 2011 | 03:45 PM
hgb4x4's Avatar
hgb4x4
This is why I liked the DUI dizzy, just plug and play with ya setup on there site and they recurve it to fit your setup and then mark it so if ya upgrade more or even change moters they can recurve again no prob like...... just an option like and is a 20+ bolt on HP gain
many do recurve there own tho on the cheap with a kit and a bit of time ect.
Old Nov 26, 2011 | 03:57 PM
86straightsix
Holy s**t! 20 hp from a recurve? I guess that is the next priority then. I am a do it your-selfer ( any reason to buy a new tool and be outside). Any idea on what kit I need?
Old Nov 26, 2011 | 04:29 PM
BaronVonAutomatc
Just out of curiosity, where were the cracks?
Old Nov 26, 2011 | 04:41 PM
BaronVonAutomatc
Using an EFI head - with smaller, fast-burn chambers - you might actually need a stiffer spring to slow down the advance.
You need the right amount of spring tension so distributor doesn't advance at idle but does start advancing as soon as you give it gas.
Get a dial-back timing light and tach. Disconnect the vacuum advance, set your base timing, then watch and record how much it advances in 250 or 500 rpm increments until it stops advancing. Then you change springs to adjust the curve for your engine.
Check this link: Duraspark_distributor_recurve_instructions_index
Old Nov 26, 2011 | 05:25 PM
fordman75's Avatar
fordman75
It's been a few years since I had mine( my memory isn't the greatest ) . But I seem to remember mine were cracked in the valve seat/combustion chamber areas. I also seem to remember the # 5 cylinder was where they were cracked.
Old Nov 26, 2011 | 06:33 PM
  #28
86straightsix
Thank you baron. That is what I needed.
vntgtrk
Oct 21, 2011 07:38 PM
F-4 GUY
May 29, 2011 12:43 AM
69 F-350
Jan 22, 2009 04:36 PM
Hooker Bob
Jan 29, 2006 04:53 PM
fordflaresides
Dec 13, 2005 02:21 PM
