how to replace door handles
Old Nov 12, 2011 | 04:55 PM
Atwiss's Avatar
Atwiss
Unhappy how to replace door handles
how do you replace the door handles mine broke the other day.......
Old Nov 12, 2011 | 07:05 PM
MaxinJaxin69's Avatar
MaxinJaxin69
Red face
1st off need to know inside handle thats opens door or arm rest handle or outside door handle?
Old Nov 12, 2011 | 07:51 PM
Atwiss's Avatar
Atwiss
Outside lol
Old Nov 12, 2011 | 07:58 PM
JB78f150's Avatar
JB78f150
You got to take the door panel off. The old handle will probably be riveted on so you will have to get that off. The new handle will probably come with bolts. Your gonna want to try to save the clips that keep the rod in.
Old Nov 12, 2011 | 08:43 PM
Atwiss's Avatar
Atwiss
I was just going to take the handle out of another door but would it be easier to just take the cylinder out of the old door and put it in the other one
Old Nov 12, 2011 | 08:58 PM
JB78f150's Avatar
JB78f150
If that's what you want to do. But you have another handle just cut the rivet spikes off it and put in bolts. Much better than swapping doors.
Old Nov 12, 2011 | 10:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on just swap the handle not a whole door. Realignment can be a PITA. Remove the door panel and look, you might already have bolts. You would only see two nuts from inside the door on the back side of the handle.
If its rivets drill the out from under the handle, pop loose the connecting rod and replace it with your new handle. Do not break the plastic slip connector. While you are at it ck the tension springs on the new handle it self.
Old Nov 13, 2011 | 08:15 AM
li_mustang's Avatar
li_mustang
i change one on my 99 e250 last month, i bought a new one .i drill the rivets and pull out the old one, for the new one i bought stainless bolts and nut ,it take me about 30 min, its an easy job ,good luck.
Old Nov 13, 2011 | 10:07 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I've never seen original door handles riveted on 73-79 doors. There is a reason there are two access holes to the nuts.
Josh
Old Nov 13, 2011 | 12:28 PM
JB78f150's Avatar
JB78f150
Josh
Both of my trucks have them. They are spikes that you stick through the whole then bend them over like a star. I believe them to be original.
Old Nov 13, 2011 | 03:42 PM
Bullitt390's Avatar
Bullitt390
Wonder if Ford got cheap with the 78 model year
Josh
Old Nov 13, 2011 | 03:51 PM
fmc400's Avatar
fmc400
MSEE
Where did he say he wanted to change out the whole door? All I read is that he was considering taking the lock cylinder out of his donor truck along with the replacement handle, instead of just the handle.
EDIT: nevermind, when I read it a different way, I see what you guys were thinking. Had to "read between the lines"
cnowotny
Apr 27, 2009 04:00 PM
Copedawg
Feb 7, 2007 01:20 PM
ken selvy
Jul 26, 2006 12:56 PM
aerostarinNorway
Aerostar
Jun 25, 2004 12:16 PM
Donald Rohret
1983 - 2012 Ranger & B-Series
Nov 11, 2003 07:53 PM
