87 STX dumping fuel
Old Nov 12, 2011 | 04:19 PM
90rangerguyNC's Avatar
90rangerguyNC
87 STX dumping fuel
After an engine swap my 87 ranger stx 2.9 is dumping fuel to the point its fouling out the plugs. What could cause this?
Also my temp gauge and fuel gauge do not work and I cant figure out why.
Old Nov 12, 2011 | 05:19 PM
bratman2's Avatar
bratman2
Possibly fuel pump diaphragm.
Old Nov 12, 2011 | 06:45 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I think you mean fuel pressure regulator
Josh
Old Nov 12, 2011 | 06:58 PM
cj06's Avatar
cj06
Josh
X2 ^^^^
ALSO IS IT FOULING ALL PLUGS OR JUST SOME ?
if it is 1 or a couple then the injectors are shot !
Old Nov 12, 2011 | 09:38 PM
90rangerguyNC
Fuel pressure reg. is what I was thinking. I have another one hangin on the wall in the garage im gonna try in the morning. It is fouling out all the plugs when its cold with fresh plugs it runs great but as soon as it warms up it starts to spit and sputter and lose power.
Also dumb question what is the switch on the dash to the right of the steering column? It can go either way but rest back in the middle when you let go
Old Nov 12, 2011 | 09:48 PM
Bullitt390's Avatar
Bullitt390
Do you have dual fuel tanks? Usually the tank selector is in that location, but it shouldn't "spring" centered.
Josh
Old Nov 12, 2011 | 10:03 PM
90rangerguyNC
No just the frame tank. I pulled the switch and it does have wires running to it but i couldn't track them. The switch is definatley spring centered
Old Nov 12, 2011 | 10:23 PM
Bullitt390's Avatar
Bullitt390
I would have to guess somebody added that switch. Previous owners have a habit of doing stuff like that.
On mine I ripped out two fog light rocker switches, an auxillary windshield washer, a JC Whitney cruise Control, a funky switch for the ac compressor and more.
Josh
Old Nov 12, 2011 | 10:28 PM
90rangerguyNC
Speaking of a/c my truck has been upgraded to the newer a/c think it could be for that? Looks to be a factory switch is the only thing that gets me.
Old Nov 12, 2011 | 10:31 PM
90rangerguyNC
Also Ive never heard of bad injectors causing to much fuel on all cylinders. Is it possible?
Old Nov 13, 2011 | 03:06 AM
mebe2k's Avatar
mebe2k
When my 88 had a bad o2 sensor years back it would dump fuel and run like a POS.. but it never fouled the plugs.. just blew a crapload of black smoke..
Old Nov 13, 2011 | 09:24 AM
Bullitt390's Avatar
Bullitt390
That's interesting... with a bad O2, the engine should run open loop and wouldn't be dumping fuel. Although gas mileage would suffer. Not much different than a bad t-stat that opens too soon. Engine computer won't go into closed loop and remain open loop, using more fuel.
Josh
Old Nov 13, 2011 | 02:49 PM
mebe2k's Avatar
mebe2k
i asked the guy at the auto part store about it and he said either the MAP or the o2 sensor..i started with changing the o2, and the problem went away.. engine ran good afterwards..it was the orig. o2 with over 100K on it.. it must have been giving the computer some out of whack readings..
back to the OP's problem.. could it be a funky TFI module? he said it fouls the plugs after it warms up.. usually thats when a bad TFI starts acting up?
AMDFX8150
Jun 14, 2015 11:20 AM
BigBlue92
Aug 15, 2012 10:30 PM
hongkongrider
Bronco II
Nov 10, 2011 10:05 PM
RbsFord
Feb 2, 2005 06:01 PM
