Sponsored by: Auxito
need help
Old Nov 11, 2011 | 11:17 AM
phillip1963's Avatar
phillip1963
need help
I have a 1997 ford f150 extented cap with a 4.6. I put a new engine in it last year it has 6000 on it. I replaced the injectors; coils; plugs all the sensers. the trouble is it runs great for about ten mins then it starts missing . I ran a code check and it says its miss firing on number 2 4 6 7 any advice thanks
Old Nov 11, 2011 | 02:20 PM
Bluegrass 7's Avatar
Bluegrass 7
That many cylinders suggest a coil pak issue or possibly water in the gas.
Good luck.
Old Nov 11, 2011 | 05:18 PM
phillip1963
I took the one back and they gave me two new ones still does it i changed everything i can think of driving me nuts .
Old Nov 13, 2011 | 09:33 PM
firefighter1416's Avatar
firefighter1416
Bad ground?
Old Nov 14, 2011 | 04:41 PM
Dave G.'s Avatar
Dave G.
What brand of coils ? What brand of plugs ? Correct heat range ?
Sounds like the problem starts when the engine is finally warm. It's not running hot ?
Old Nov 15, 2011 | 11:12 AM
phillip1963
I bought motorcraft got everything though napa it is not running hot, now it has a ping in it when i hit the gas or ging up hill . I love my truck it is really good shape for a 97 i put 4k in it so far with the new engine and all the parts want to get it painted and make it last 10 more years nice not having a payment
Old Nov 15, 2011 | 12:40 PM
Bluegrass 7
A good scanner to look at the ignition timeing live will get you an idea what the timing is doing to cause ping.
Scanner will tell about the fuel tables.
Lean codes should tell about air leaks for to much air.
Three ways ping comes about.
1. To much ignition timing caused by a fault. Often with the EGR system.
2. Fuel to lean, not enough fuel pressure at the injectors for the pulsewidth being applied to the injectors.
3. To much air for the fuel metered by the injectors.
Good luck.
frenchsquared
2004 - 2008 F150
Jun 23, 2018 08:25 AM
Clint S
1997 - 2003 F150
15
Jan 20, 2010 08:41 PM
woogs
1997 - 2003 F150
Mar 20, 2007 11:34 AM
50th ann
Modular V8 (4.6L, 5.4L)
Jan 7, 2006 05:46 PM
rp12345
Feb 9, 2004 06:00 PM
