IPR QUESTION ON CLEANING
Old Feb 5, 2012 | 09:39 PM
oldbird1965's Avatar
oldbird1965
Rick, you took the words right out of my mouth, LOL!!
Old Feb 5, 2012 | 09:47 PM
redman84's Avatar
redman84
Change the HPOP oil then install one of these while you're at it:
Old Feb 7, 2012 | 11:35 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by Action4478
Here we go ....
oh no
Old Feb 7, 2012 | 12:51 PM
DIYMechanic's Avatar
DIYMechanic
Originally Posted by MONAVIERONJON
ive seen the newer rebuild kits have a screen on the tip that sticks into the hpop side. The new o ring kit is highly recommended when removed. These things get clogged and often cause a no start situation as the hpop oil system tends to not get changed when doing a routine oil change. The only way is to pull the oil up out of the hpop fill hole.
You know you guys are contributing to this by joking about it right? We joke areound by talking about the top end oil change, people (not knowing we are joking) google it and end up....where else? Powerstokehelp.com
ANYWHO, You do not need to "change the oil" in the HPO system. It pulls oil from the crank case and dumps it back on top the heads after it passes through the injectors. I change my HPO oil every time I turn the key.
And for what it's worth don't listen to anything that slick ***** (Bill) says at Powerstrokehelp.com. He is either wildly misinformed or a crook who is intentionally misleading people to make a profit. His videos are good for nothing other than entertainment once you know what you're looking at with a Powerstroke. I hate to bask on someone, but that guy doesn't tell the truth in his videos, either ignorance or greed is to blame I'm not sure which. How's that for "the volcano effect"?
Old Feb 7, 2012 | 07:30 PM
JamesHajek's Avatar
JamesHajek
It gets changed everytime you blip the throttle.....
Old Feb 7, 2012 | 08:02 PM
Action4478's Avatar
Action4478
The system is designed to 'not" have the problem you are describing
Its not a "newer " re build kit .. the screen on the end is the edge filter ..
it is the early version of the IPR . The later , has the Edge filter up stream in the pump ...
snorindad
Dec 31, 2020 09:03 AM
timmyboy76
20
Aug 27, 2011 12:04 AM
MercM47
Oct 24, 2003 11:57 AM
