IPR QUESTION ON CLEANING
Old Nov 10, 2011 | 07:48 PM
bird-n-buck's Avatar
bird-n-buck
Trailering
95 f-350, took the ipr out and cleaned it the instructions said the small plunger in the pilot valve should push in about an 1/8' and pop back out. Mine does not even stick out 1/8" and it will not push in it is solid. Someone else told me there is supposed to be a ball under the plunger but I did not find one or I lost it. Anyone know what it should be like.
Old Nov 10, 2011 | 08:29 PM
fordpride's Avatar
fordpride
No ball
Old Nov 11, 2011 | 10:36 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by fordpride
No ball
The screen and the type of little punch that are in the pic doesnt are part of the IPR, right?
Old Nov 11, 2011 | 10:38 AM
bird-n-buck
Trailering
Thanks for the picture, I need to know if that small needle valve should be able to be pushed into the pilot valve and pop back out mine is solid when you try and push it into the pilot valve and since mine is solid does that mean the insides of the pilot valve are hung up and do not move.
Old Nov 11, 2011 | 02:13 PM
fordpride's Avatar
fordpride
Jose the screen and punch are not part of the IPR
Old Nov 11, 2011 | 02:15 PM
fordpride's Avatar
fordpride
Yes you should feel it move up and down just a little if your isn't moving then the IPR is bad
Old Nov 11, 2011 | 08:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Thank you. I like your new avatar, BFH LOL
Old Nov 11, 2011 | 08:59 PM
fordpride's Avatar
fordpride
i figured some of you would get a kick out of the BFH lol
Old Nov 11, 2011 | 11:28 PM
oldbird1965's Avatar
oldbird1965
Save a window, smash the parts on the driveway, huh Mike?
Explain to me what parts in the picture should move in and out a little?
Old Nov 12, 2011 | 09:16 AM
fordpride's Avatar
fordpride
sorry i jacked up original post
You should be able to push a small screwdriver from the end of the IPR and feel it move
Red arrow
Old Nov 12, 2011 | 07:09 PM
MONAVIERONJON's Avatar
MONAVIERONJON
I've fixed quite a few things with a BFH......as for the ipr,blow out the larger pieces with compressed air and before assembly lubricate with some fine oil,best to replace the o rings on it before reinstall .Good luck!!
Old Feb 5, 2012 | 05:05 PM
dougbrown's Avatar
dougbrown
Do u have to pull the fuel bowl to do this? how do u know it need to be cleaned?
Old Feb 5, 2012 | 06:00 PM
fordpride's Avatar
fordpride
You don't have to but it helps. To be honest I don't know if cleaning helps when I pulled mine apart at 200k it was spotless
Old Feb 5, 2012 | 09:08 PM
MONAVIERONJON
ive seen the newer rebuild kits have a screen on the tip that sticks into the hpop side. The new o ring kit is highly recommended when removed. These things get clogged and often cause a no start situation as the hpop oil system tends to not get changed when doing a routine oil change. The only way is to pull the oil up out of the hpop fill hole.
Old Feb 5, 2012 | 09:23 PM
Action4478's Avatar
Action4478
Here we go ....
