Sponsored by: Real Truck
A few lighting projects
Old Nov 14, 2011 | 06:57 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Thanks
Yeah, the puddle lights turned out pretty good. Still working on the writeup and I'll post up a link when its ready.
I tried to size up my amber marker lights yesterday and found out that I need 4 per side instead of 3. I couldn't get the spacing I want with 3 so I have a few more on the way
By the way, here's the marker lights I'm going to use.
M11 series Truck Clearance Marker Lights
Old Nov 15, 2011 | 06:38 PM
1975StroppeBaja
Here's the link http://www.frontiernet.net/~jmray/F250PuddleLights.htm
Old Nov 24, 2011 | 04:36 PM
1975StroppeBaja
I managed to get the marker lights installed this week in between rain and hunting.
No writeup yet but here's a few teaser pics...
Old Nov 24, 2011 | 08:29 PM
Craig.Parks's Avatar
Craig.Parks
Looks good!
Old Nov 24, 2011 | 08:44 PM
Trophy_23's Avatar
Trophy_23
Can't wait for a write-up, looks great! Would love to see a close-up pic of one of the lights. Do these have a ground wire or just grounded by tightening the bolt?
Old Nov 25, 2011 | 12:19 AM
1975StroppeBaja
The ground is just the stud that you bolt them on with. I actually ran a ground wire to each stud. Superbrightleds.com part number M11PC-A3. Here's a few more pics...
This drawing shows how I did the wiring for the lights and the next pic is a close up of one of the lights on the backside.
Old Nov 25, 2011 | 02:48 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
very nice on the side marker lights. I did something very similar on mine.
how did you get them powered? did you run it from inside the cab or from the 7 pin hitch (how I did it)
Old Nov 26, 2011 | 08:50 PM
1975StroppeBaja
I brought mine inside the cab. Only reason was, I already had an easy way in on the driver's side. When I installed the Pop & Lock tailgate lock, the wires weren't long enough to go up to the firewall through the plastic plug (the way I normally get wires in/out) so I drilled a hole to poke the loom up through. So, I used this loom to get into the cab.
Problem with that was, I had to drill another hole in the pass side to match. Then had to snake the wire across behind the dash to the driver's side since there's no park light wire in the pass side loom.
Here's the hole I was talking about:
Old Nov 27, 2011 | 09:41 PM
1975StroppeBaja
Ok, all the marker light details are here:
2004 F250 Marker Lights
Lighting projects are always fun and these ones didn't disappoint. I'm really surprised I was able to get all three done this time of year. Weather's holding out really well so far.
Old Nov 27, 2011 | 10:43 PM
Furian's Avatar
Furian
You Keep What You Kill
SWEEEEEET! Another excellent job and write-up Jason!
Old Nov 28, 2011 | 01:05 PM
Robby Nash's Avatar
Robby Nash
That's right. Its made by PEAK and was (maybe still is?) sold at Sam's Club stores.
more info here... 2004 F250 Reverse Backing Alert System
Do you have a picture of how this is mounted in your truck??
Old Nov 28, 2011 | 01:14 PM
Robby Nash's Avatar
Robby Nash
oops sorry wrote to fast just saw it in the write up.
Old Nov 28, 2011 | 09:13 PM
  #28
1975StroppeBaja
Thanks
The aux reverse lamps are crazy-useful. I've already used them a ton, wish I would've installed those years ago.
Old Mar 28, 2020 | 11:13 PM
  #29
murraydav's Avatar
murraydav
Why go through all that grief. They sell a 60 inch peel and stick LED strip. Left turn, right turn, brake, flasher, AND BRIGHT WHITE REVERSE
Plugs right into flat 4 harness Ten minit install 19 bux. ONLINE BUDD
LiquidSteam
Aug 17, 2017 06:34 PM
PwerStroke99
Oct 30, 2016 05:00 PM
Hitokori
13
Dec 14, 2010 02:15 AM
skylinekw
6.7L Power Stroke Diesel
20
Nov 10, 2010 08:58 AM
AlaskanEx
Oct 15, 2010 09:44 AM
