Sponsored by: Real Truck
V10 starting problems
Old Nov 9, 2011 | 04:46 PM
Gregv10's Avatar
Gregv10
I have a 2009 f250 v10. Sometimes it cranks for a while before starting. Anyone have any ideas as to why?
Old Nov 9, 2011 | 05:00 PM
1973Ford2004's Avatar
1973Ford2004
how many miles? Any maintenance?
Old Nov 9, 2011 | 05:05 PM
Gregv10's Avatar
Gregv10
119,000 miles. I just bought it and don't know much past maintenance history other than the ford oasis I had ran on it. It has no blow by nor does it smoke any.
Old Nov 9, 2011 | 05:20 PM
pappy19's Avatar
pappy19
You first need to post this on the 6.8-V-10 forum down on the list. Second thing I would do is clean the MAS and go from there.
Pap
1973Ford2004
I'd start with the plugs.
Old Nov 9, 2011 | 05:23 PM
redford's Avatar
redford
FTE Leadership Emeritus
Plugs, air filter, fuel filter.
Give it a tune up, perhaps a new battery, then see how it starts.
Old Nov 9, 2011 | 05:29 PM
Gregv10's Avatar
Gregv10
Battery, fuel and airfilter are all new.
Old Nov 9, 2011 | 05:34 PM
1973Ford2004
plugs, Greg and maybe a COP or 2.......search the forum changing the plugs ain't that bad and you'll see a world of difference
Old Nov 9, 2011 | 05:37 PM
Gregv10's Avatar
Gregv10
It has been hooked to the computer at a ford dealer. ECM shows no misfires and the check engine light is not on.
Old Nov 9, 2011 | 05:39 PM
barthel's Avatar
barthel
Fuel filter, fuel pump.
Old Nov 9, 2011 | 05:40 PM
Gregv10's Avatar
Gregv10
Just had a friend tell me that a diaphragm in the fuel pump could have a hole in it allowing fuel pressure to bleed off.
Old Nov 9, 2011 | 05:49 PM
barthel's Avatar
barthel
I don't believe the electric in-tank pumps have diaphragms, they're turbine style.
Replace the fuel filter, check the fuel pressure, and of course do the other "maintenance" items that others have noted in this thread. Clean MAF, IAC, replace PCV & air filter, COP boots and plugs. NEVER a bad idea to handle these things.
Old Nov 9, 2011 | 06:13 PM
redford's Avatar
redford
You do not have a mechanical fuel pump. That advice might be appropriate if you were driving a 1974 F-250 with a 390 CID V-8 in it.
TrucksNCoffee
Feb 26, 2019 07:29 PM
ghostryd3r
May 12, 2009 03:45 AM
freddydiesel
Mar 13, 2007 07:08 PM
Hockycop
Oct 3, 2004 01:46 PM
crews
Mar 24, 2004 03:19 AM
