Battery died while driving
Old Nov 9, 2011 | 07:56 AM
65fordguy's Avatar
65fordguy
Driving to work my trucks radio turned off.. My abs light came on.. A screeching sound from front hubs.. Then I stopped abs light went off hubs locked.. Air bag light came on.. I hit the power button on radio it displayed low battery.. All interior options were off. Outside lights dim .. When I got to work I shut it off and tried to restart... Acted like battery was dead.. It's a 3 week old battery. I also noticed , it seemed like I could not turn off my head lights.. Switch did not seem to make any difference with lights. After being off for a mon. The lights got a little brighter. Any advise? Is it just the alternator? I got no low battery or dummy light. It did have a mildly sluggish start.
Old Nov 9, 2011 | 08:06 AM
MCDavis's Avatar
MCDavis
The alternator is not charging for some reason. Bad alt? Bad wiring? Bad ground? I'd have the alt tested before going any further.
Old Nov 9, 2011 | 01:49 PM
Coskid's Avatar
Coskid
Yeah I agree with Chandler check out the alternator or the wiring.
Old Nov 10, 2011 | 05:54 PM
aquaman's Avatar
aquaman
If you have a voltmeter, you can check real quick.
With the engine running, you should see at least a steady 13.5V or so.
If it bounces around or is anything less, suspect the alt brushes are worn out.
Old Nov 14, 2015 | 01:57 AM
Tedster9's Avatar
Tedster9
Instrument cluster only has warning light?
I've taken to using (Innova) these, about $10, since nobody seems to want to pull duty in the engine bay and monitor voltage on the fly:
Old Nov 14, 2015 | 05:02 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Sounds like it's not charging to me as well. A fuel pump that is running will drain a battery pretty quick and starve all other accessories.
cr250
1997 - 2003 F150
Mar 26, 2019 10:00 AM
Krataxx
Escape & Escape Hybrid
Feb 11, 2013 09:20 PM
embry1123
Dec 15, 2009 08:00 PM
Futuresweets-10
Nov 13, 2008 11:46 AM
tex599
1983 - 2012 Ranger & B-Series
Aug 4, 2004 07:10 AM
