Check Battery Light on Dash?
Old Apr 7, 2004 | 11:22 AM
tex599's Avatar
tex599
My check battery light comes on and my voltage gauge is lower than normal. When driving it will sometimes go off when on the highway but come back on. But the battery check at 12.8 volts when running and about 12.0 volts when engine is off. Does this sound like a bad alternator or faulty gauge?
Is the battery light set off by the voltmeter on the dash?
Thanks
Old Apr 7, 2004 | 11:55 AM
mymechanic'sanidiot's Avatar
mymechanic'sanidiot
Are any of your dash lights dimming? Maybe the radio getting harder to hear cause the volume doesn't seem to work as well anymore. My battery light came on too. I know these days those lights are usually warning you your alternator's dyin. I know when the alternator went on my ole Chevy Cavalier, thank goodness I saw the Ford light!, that's what happened. Next thing I know I'm stuck in a bad part of town. But that's just my $.02 worth
Old Apr 7, 2004 | 12:07 PM
WildOneCraig's Avatar
WildOneCraig
When my alternator was on its way out it had weaked my battery. I turned everything on lights, signals, radio , heat etc... the truck then stalled out. A for sure sign. without testing the alternator. Mind you your mech. can test the load output in 2 mins. and be sure. cheers
Old Apr 7, 2004 | 12:23 PM
HomerWinzlow's Avatar
HomerWinzlow
The check battery light is really a check charging system light. You should be getting closer to 14.25 running. Probably got an alternator going down or extremely corroded connections.
Old Aug 3, 2004 | 05:19 PM
fisholot's Avatar
fisholot
I had the same thing with the light and good charge.
I changed plugs and wires now no more battery light.
didnt really think the two were connected.
Old Aug 3, 2004 | 10:07 PM
DainBramage's Avatar
DainBramage
I'd get the Alt checked asap. That's exactly what mine did, then it got progressively worse, until it died completely. For once, it happened right in my driveway!
I initially thought it was my serp belt or tensioner slipping because it would only do it at higher RPMs, but, as I said, it got worse.
Old Aug 4, 2004 | 07:10 AM
jrpatterson's Avatar
jrpatterson
You can take your alternator to any good auto parts store and they can tell you if your alternator is putting out enough juice .. for free!
jasindude1
Sep 19, 2014 06:02 PM
92 Red F150
Sep 16, 2014 09:12 PM
jon705
Electrical Systems/Wiring
Apr 14, 2013 10:21 AM
LonelyRoad2004
May 20, 2004 10:05 AM
Mikey Hot Dog
Aug 29, 2003 09:55 AM
