turning up pump
Old Nov 8, 2011 | 11:44 PM
christian.lewis's Avatar
christian.lewis
turning up pump
So i was thinking about turning up the pump. I have a egt gauge already so i could tell the temp. All my buddies do it on the cummins but non of them have an IDI. What do you guys think? if its ok to do how much should i turn it up?
Old Nov 9, 2011 | 02:38 AM
joshofalltrades's Avatar
joshofalltrades
go one step at a time, and if you're able to blow black smoke, that smoke is wasted money with no more power. keep it in moderation.
Old Nov 9, 2011 | 08:16 AM
greywynd's Avatar
greywynd
Not sure of what else is done to your truck, but as mentioned, black smoke is a waste of fuel. At that point you're getting more fuel than air, so if you hit a limit, and your EGT's are still low, try to modify or improve your air intake to get more air in to it.
Old Nov 9, 2011 | 09:14 AM
hairyboxnoogle's Avatar
hairyboxnoogle
1 flat or 1/6 of a turn i usually the measurement used.
Old Nov 14, 2011 | 10:24 AM
bankspro6811's Avatar
bankspro6811
where do you turn the fuel up at? i think im running lean, because i have a banks turbo and as far as i know there has been no adjustment to the pump.
Old Nov 14, 2011 | 10:43 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/8...ctor-pump.html Have a read here for instructions.
Old Nov 14, 2011 | 11:28 AM
bankspro6811
thanks! that was a great help!
deceptichop
48
Sep 9, 2010 04:51 PM
Dev
21
Jun 17, 2010 09:06 PM
deanzawistowski
17
Dec 20, 2007 05:25 PM
travertine
Nov 11, 2004 03:00 PM
Fuzzys69
Sep 30, 2003 07:31 PM
