Ford 292 Disassembly
Old Nov 8, 2011 | 12:11 PM
ALL AMERICAN BOY's Avatar
ALL AMERICAN BOY
any tips for taking these apart?
DIY Signature
292 & Fordomatic out of
'60-'64 pickup truck
Old Nov 8, 2011 | 05:09 PM
HT32BSX115's Avatar
HT32BSX115
it's out of a truck
has 'oil to water' transmission cooler
fordomatic trans ( very grungy )
2 bbl and cast iron manifold
crossover exhaust
Howdy and Welcome aboard!
Well it might depend on what you're planning to do with it after you take it apart!
It's just a V-8. there's no real special way to disassemble it different from any other V-8.
If you're planning to rebuild, and resize rods, re-do heads etc, you don't even need to number anything.
If you're going to try to re-use rods, pistons cam followers etc.....You should probably mark everything in such a way that you can put them back into the same "hole"(s) they came out of....
Cheers,
Rick
Old Nov 8, 2011 | 05:22 PM
raytasch's Avatar
raytasch
Believe Nothing
Couple of things come to mind. Pay attention to where the long head bolts come out. A few misc. bolts in the engine run into the water jackets and will need sealer. Rocker oiling in these engines is through the #3 cam bearing and they do tend to get stopped up. Note the timing marks are not what you might expect.
Welcome to the forum.
Old Nov 8, 2011 | 05:32 PM
ALL AMERICAN BOY
when we reply to thread
it DOESN'T SHOW TITLE of what we're
responding to
HT32
cam followers?
well maybe not rebuilding it
right now just removing accesories
to move engine & trans
and we're told it had 'spun bearing'
let's all think happy thoughts
it's not broken crank
thank you ray tasch
haven't gotten to long block yet
Old Nov 9, 2011 | 12:19 AM
HT32BSX115's Avatar
HT32BSX115
292 Disassembly
responding to
HT32
cam followers?
thank you ray tasch
Well, that might be problematic. you won't know until you get in there.
Ditto on the head bolt lengths. In fact there's more than a few assembly errors that might need to be addressed.
It's probably best to go HERE: Ford-Y Technical
Do a little reading!
Old Nov 9, 2011 | 03:39 PM
ALL AMERICAN BOY
thank you HT
DIY Signature
Old Nov 9, 2011 | 11:28 PM
46yblock's Avatar
46yblock
To remove front pulley/damper, use a damper puller, not a 2 or 3 jaw puller. And hammers and crow bars on the damper arent good ideas either. Cam followers i.e. lifters, solid lifters, mushroom lifters.
Old Nov 9, 2011 | 11:49 PM
ALL AMERICAN BOY
thank you 46 yblock
DIY Signature
sdloe
Aug 7, 2012 09:36 PM
StatikPulse
Aug 2, 2012 03:41 PM
F-250 restorer
Oct 8, 2009 08:09 PM
tuckerjw
Feb 17, 2008 09:30 AM
rxfx101
Apr 6, 2005 01:57 PM
