What part is missing
Old Nov 7, 2011 | 08:12 PM
Slankky's Avatar
Slankky
Hey guys I'm pulling # 6 injector and have accessories off but now see a hole in the drivers side valve cover with no part in it what go's there? Does it have to do with CCV?
2003 crew,4x4,6.0L,auto,K&N air filter
Is this a cover up from last owner?
Or does it have something to do with the K&N vs stock air intake?
Old Nov 7, 2011 | 08:20 PM
BLADE35's Avatar
BLADE35
Its the CCV if its about 1 inch hole driver side valve cover is it missing the elbow in the intake to valve cover
the stock setup air filter is the best sounds like somone changed it out and not in a good way might have to go see what you can get from the junkyard
Old Nov 7, 2011 | 08:26 PM
Slankky's Avatar
Slankky
junkyard
Yes just a hole. What does the elbow connect to? What negative affects has it possibly been causing?
Old Nov 7, 2011 | 08:34 PM
Slankky's Avatar
Slankky
I see now that u said " intake to valve cover " do you know of a pic on here to show? I couldn't find one. I looked for a while. And thank you very much for this and other responses in the past.
Old Nov 7, 2011 | 09:00 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here, look at the second picture. It's #9 in the shot.
https://www.ford-trucks.com/forums/7...ml#post8172940
The third picture is a better shot.
Old Nov 7, 2011 | 09:02 PM
BLADE35's Avatar
BLADE35
Its kinda a Z shape tube that goes from valve cover to plastic intake parts coming from the Air filter housing to the cold side of the turbo
The problem is the Air intake is sucking Dirt right there into the turbo the valve cover side may or may not have positive pressure
I dont know of any pics to help you I know them pics are worth a 1000 words but if I come acrooss one I will post up
the other inlet of the CCV is on the bottom of the plastic Air intake
Old Nov 8, 2011 | 12:37 AM
Slankky's Avatar
Slankky
Sorry guys was a false alarm but I did learn from it.
I went to garage and checked parts, I didn't realize that it came out still attached to the K&N top (lid) and I only saw the open hole.
Thanx again to you guys for your replies, info and research.
MatterOne
1997 - 2003 F150
Oct 26, 2015 03:34 PM
vics66
Feb 26, 2011 07:07 PM
danzigs
Dec 22, 2010 04:05 AM
jmm
Mar 3, 2010 07:23 PM
DMAN
Apr 15, 2005 09:36 PM
