How To: 6.0L CCV Re-route
#63
Just to document my learnings:
I have switched to a Racor ccv filter (I took out the original one I started with). The oil degraded the glue on the first filter. Also, I upgraded to 1 inch hose (instead of 5/8 inch or 3/4 inch). It does make a difference. I calculated and measured the back pressure!
Also, I installed the ccv-6000. It is huge and expensive. I would think that it is adequate to install the next size down (ccv4500 IIRC). I installed the larger one for the potential of higher horsepower mods "down the road".
#65
Fellas,
I plan on doing the CCV mod to my truck soon. However, the truck budget is a little low right now. I will be changing out my air filter and installing a fuel pressure guage this weekend. While doing that I figure it would be a good time to go ahead and at least install the plumbing for the CCV filter. I will be installing the CCV6000 filter and routing the line back to the intake (close loop) like what Bismic has shown here.
Do yall foresee any problems if I just make one big loop without the filter and then just cut the pipe and install the filter later? Unfortunitly, $$ and free time are hard to come by and only have the free time right now. Assume there would be no problems doing this, just wanted to double check.
Thanks for any input.
#66
#67
#68
The outlet can go back to the turbo inlet - it is essentially oil-free. Plumbed to the turbo inlet, you get a nice vacuum pulled on each acceleration. I suppose you could plumb it into the exhaust line or leave it open at the rear of the vehicle, but I greatly prefer beig plumbe back to the turbo inlet. If you do plumb it somewhere else, make sure the opening in the turbo inlet duct is properly plugged.
#69
#70
#73
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: CCV Filter
Here is the link to my setup...installed in Aug 2009, just ordered my replacement CCV6000 Racor filter for $40 bucks off ebay and will replace this weekend. More updated pics to add to this album showing One year of filter use. The CCV6000 comes with a brass drain fitting on the bottom of the filter bucket...mine did not have a cap so I picked one up at The Home Depot.
#74
Sorry I did not answer, I did not see this Jonathan. I retrofitted my filter base w/ a drain **** valve - like for an air compressor.
