7.3 quits running while driving
Old Apr 22, 2012 | 01:50 AM
  #31
4inchlovin's Avatar
4inchlovin
what brand code reader did you use? not all code readers read PSD codes unless it is specified on it.
Old Apr 22, 2012 | 02:52 AM
  #32
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Edgeotime
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->
my 03 7.3. Pulled over to the side of the road and installed my "spare" CPS. No start, no tach
FYI: 2002 and 2003 will not show tach movement while cranking.
Old Feb 4, 2015 | 10:46 PM
  #33
csmartin's Avatar
csmartin
to baddad457 how much did that cost you? I'm pretty sure that may be what's wrong with my truck
Old Apr 9, 2017 | 10:24 AM
  #34
Hannah 2000's Avatar
Hannah 2000
7.3 quits and runs when it wants
I have this exact same problem...I can drive the truck for days and she is fine... Then out of no where she quits...strange thing is if I open the fuel drain on the filter she may start...but if she sits for an hour or so she starts fine and may run good for whoever knows how long and then without any warning quits again... I have changed everything even taken the tank out to check fuel lines as well as putting on a new lift pump... All sensors are replaced I am down now to thinking may be HPOP but they are expensive and want ideas before that..
I am a diesel mechanic and have never experienced anything like this... All help is appreciated PLEASE
Old Apr 9, 2017 | 12:52 PM
  #35
hydro man 17's Avatar
hydro man 17
Hannah, this is a very old thread. You should start a new one. My memory is failing me at the moment but I think that the ICP sensor is heat sensitive when going bad.
Old Apr 9, 2017 | 01:17 PM
  #36
Stewart_H's Avatar
Stewart_H
Yes. This.
Stewart
KT403
Oct 22, 2014 03:33 PM
Jonesd253
18
Nov 13, 2012 08:38 PM
bass-n-fire
31
Oct 8, 2012 08:11 PM
shortys07
25
Dec 24, 2008 06:54 AM
FastOldGuy
13
Nov 16, 2006 08:05 PM
